rhysy_boi Member 83 Member For: 18y 11m 15d Gender: Male Location: Perth, WA Posted 31/10/07 10:48 AM Share Posted 31/10/07 10:48 AM guys I've had a scare with the car misfiring and detonating etc and I'm getting it retuned next week by simon at XFT. I think it's been having some problems for a little while but possibly a bad batch of fuel bought it to my attention. I still have half a tank of this fuel in the car but I can't for the life of me find a drain point.I want to dump the fuel just in case it was a bad batch and chuck a new tank of 98 in before it gets tuned.HELP!Rhysp.s. it's a ute if that helps Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/ Share on other sites More sharing options...
Wright'y Member 226 Member For: 21y 3m 14d Gender: Male Location: Darwin, NT Posted 31/10/07 12:50 PM Share Posted 31/10/07 12:50 PM I have a sedan so I dont know about utes, but in a sedan you would have to drop the tank.You might have to drive like a grandmar untill your almost empty, then fuel up with 98.Also put a new fuel filter in when you have been running 98. Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-590879 Share on other sites More sharing options...
ExAreSix TRAITOR Member 1,063 Member For: 22y 8m 11d Gender: Male Location: Townsville, NQ Posted 31/10/07 01:02 PM Share Posted 31/10/07 01:02 PM (edited) You could make a drain plug? Drill a hole, thread tap it, and put a threaded plug in it. Then you've got a drain plug. Legalities? Unsure...Afterthought: Plastic tank, probably not possible to thread it.Or maybe disconnect your fuel line, stick the fuel line in a container, turn the ignition on. Use the fuel pump to empty it...?? In a sedan I'd simply lift the pump assembly out of the tank, stick a hose in there and either syphon it out, or hook a 12V pump up to it. Not sure with the ute. You'd have to take the tray liner out, and even then you can't lift the pump assembly out of the tank. You may be able to lift it out enough to stick a hose in there though...?Just throwing around ideas, I really have no idea. Edited 31/10/07 01:06 PM by ExAreSix Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-590888 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 16d Gender: Male Location: Sydney Posted 31/10/07 11:32 PM Share Posted 31/10/07 11:32 PM There are several ways:Remove the tank and drain: Sucks and a lot of workorUse the fuelpump to pump it out. Do this by disconnecting the main line from the fuel rail and put it into a suitable container.orGet a syphon and suck it out. Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-590976 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 7d Gender: Male Location: Perth Posted 31/10/07 11:54 PM Share Posted 31/10/07 11:54 PM Leave it parked in balga with a piece of garden hose hanging out of the tank and a few empty 2ltrbottles laying around it'l be bone dry in 15mins, other wise pump it out with the fuel pump. just dont run the pump dry. why cant you just dump a bottle of NF104 in it and drive like miss daisy till its empty? Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-590984 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 10m 6d Location: Brissy Posted 01/11/07 10:45 AM Share Posted 01/11/07 10:45 AM Yeah use the fuel pump, just take out the fuel filter connect a hose & turn car to ON, it's bout 1/2 way down the car just inside the chassis rail, may as well get a new one whilst your at it, if it's bad fuel could have crap in your fuel filter anyways. Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-591275 Share on other sites More sharing options...
rhysy_boi Member 83 Member For: 18y 11m 15d Gender: Male Location: Perth, WA Posted 01/11/07 11:18 AM Author Share Posted 01/11/07 11:18 AM yeah I got the filter replaced while it was getting serviced, whats NF104? I was thinking I may aswell just baby it a little bit then fill it up before I get it tuned. it's a good 100km trip to work and there the day I get it tuned.cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-591289 Share on other sites More sharing options...
FLASHXR Donating Members 135 Member For: 19y 9m 17d Gender: Male Location: Sydney Posted 01/11/07 11:45 AM Share Posted 01/11/07 11:45 AM Yeah use the fuel pump, just take out the fuel filter connect a hose & turn car to ON, it's bout 1/2 way down the car just inside the chassis rail, may as well get a new one whilst your at it, if it's bad fuel could have crap in your fuel filter anyways.Speaking from experience, using the cars fuel pump with the fuel line off doesnt work... Cars in the past would just pump petrol as soon as you flick the ignition switch to reds, but these falcons wont pump fuel until it detects ignition spark... So the only way to get it to pump is by holding the key in the start position... So basically, the battery will be flat by the time you get 1 litre out of it...Cheers Trent Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-591308 Share on other sites More sharing options...
XR_Brute Member 120 Member For: 18y 2m 29d Gender: Male Location: melbourne Posted 01/11/07 12:04 PM Share Posted 01/11/07 12:04 PM (edited) Trent, seems your experience isnt very extensive......The way we do it at work is to disconnect the supply line, and run a hose into a container, then remove the fuel pump relay and bridge the terminals with a wire, will drain a fuel tank no problems, I do it all the time on AU/BA/BF... we get alot of fuel contamination jobs at the dealer I work at Edited 01/11/07 12:06 PM by XR_Brute Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-591312 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 7d Gender: Male Location: Perth Posted 01/11/07 12:06 PM Share Posted 01/11/07 12:06 PM (edited) edit: xrbrute beat me too it..... Edited 01/11/07 12:07 PM by hiddeous Link to comment https://www.fordxr6turbo.com/forum/topic/39435-how-do-i-drain-my-fuel-tank/#findComment-591313 Share on other sites More sharing options...
