  • Member For: 18y 9m 27d
I have an xr6t that has been edited with wog cooler f6 CAI exaust mod running 260atw.
I want to know if fitting a 83c thermostat would help or do I need to do a retune for the thermo fans to come on?
https://www.fordxr6turbo.com/forum/topic/39149-thermostat-after-edit/
  • Member For: 19y 10m
While I have seen tuners fit these I have never seen the point, even after an edit I have never seen my car get above half and that's with giving my car a flogging on a hot day with the aircon on.
  • Member For: 18y 11m 10d
The ecu will start to pull timing based on several temp related paremeters, fitting a lower temp thermostat, will keep the temps lower so the ecu will give a more consistant timing setting, basically it does not give more power, it keeps the power consistant
Guest newl
  • Guests
I've been really considering replacing mine as the fans are now becoming annoying. Does anyone have a maker and part number of said thermostat and a suggested place to pick one up (if not, I can ring around to a few larger mobs to see if they have in stock or can order one).
  • Member For: 18y 1m 23d
I bought one from C&V for $35. haven't fitted it yet.
:bangcomputer:
Most automotive shops, eg Repco will sell them to you for under $20
I paid $13 for my 72 degree one that I have in the EF...
Edited by kissy
  • Member For: 22y 1m 7d
you can run a cooler thermostat but depending on the tuning of cold start parameters you might still be on a little choke (cold fuel enrichment) at 80 degrees. . You really need to check with someone who has access to the tuning tables. eg at 80deg you might have +3% fuel being added phasing out to 0% at 85deg
Edited by turbotrana
  • Member For: 18y 13d
whats the standard stat rated at? 85? 88? I'm considering doing this too
My Car: BA MK 2 6speed M. Was 93 c , is now 88c.
Go to Super Ch. Auto and look for Tridon Thermostat TT1 -190 = 88c, or TT1- 180 = 83c.
Was just under 13.00 dollars and is the right shape so the O-ring will seal.
When you get the new one, drill the extra hole that is in the original one !!
Edited by f-wolf
  • Forged Member
  • Member For: 18y 3m
if you're going to drill holes, you might as well put holes in the original, it will do the same thing
