  • Member For: 19y 8m 7d
Posted
I'm sure a post like this has been done to death, but I just brought 3 gauges boost, oil pressure and air/fuel ratio and I was wondering if anyone knew how to install them all or where in Melbourne I can get it done with out costing a arm and a leg???????
  • RUS531
  • Legacy Donating Member
  • Member For: 20y 27d
Posted
search the forum mate theres alot of info about installs. I ran the power and ground from the mobile phone connector behind the fuse box illumination from the TC button and I haven't wired the sensors on mine in yet but for oil press and temp I'm getting a sandwich plate. and I'm still gathering info for the AFR
Posted
thanks for your help RUS531 I was thinking of getting the power for the lighter and I just picked up the plate that goes on the oil filter so that's taken care off it's just the others I'm not sure about now
  • Member For: 19y 4m 3d
Posted
I've got a BF and I've tried black and grey so far for the o2 sensor.. still no readings :D
guess I'll just try them all.
  • Member For: 21y 10m 29d
Posted
bf turbo did you let the car run for a while, as the airfuel wont just work straight away it needs to heat up
Posted
Yep going now, lots of action on the black wire. way too much action really doesn't actually peak but bounces between lean stoich and rich flashing the warning light each time it hits rich or lean lol...
I now see where the term disco lights come from..Man it was a bastar$ to install as well.
Posted
ahh glad you got it working
and yeah they dance around a bit, I have the mechanical version and the needle moves a bit but not as much as the light up ones
Posted
I might take a video and put it up.. you can tell me if its all normal.. :D
  • Member For: 19y 7m 6d
Posted
I've got an AFR guage ( led one ) and they dance around 90% of the time. Only sits on rich at full throttle or heavy load. I'm actually thinking of replacing it with oil temp. Mine is autometer cobolt and cant see the lights during daylight.
Posted
Yeah chuck one up but it will dance a bit and when you are stopped or on idle it will just sweep from side to side
that's why I bought the mechanical version see it clear as day anytime
