sport Member 62 Member For: 22y 1m 1d Posted 11/10/07 10:36 AM Share Posted 11/10/07 10:36 AM Hi all, I have a stage 1 Nizpro edit on my BF F6 and could not be happier with how it performs. My brief was for it all to appear standard so they have enlarged my injectors but not replaced the cat.It makes 280 rwkw but unless I am reading the printout wrongly, it shows max boost of 14 psi. The 14 psi section of the boost curve lines up with about 210 rwkw on the power curve but where the power initially paeks at 280 the boost has settled back to about 12 psi. So my question is, when you guys talk about power at a certain boost which part of the power and boost curves are you talking about. Regards, Sport. Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 14d Gender: Male Location: SW Sydney Posted 11/10/07 11:35 PM Share Posted 11/10/07 11:35 PM you'll find that because your intake and exhaust is practically stock, the turbo has to work harder to produce those numbers, if you were to replace the car, a better cooler and some valve springs, you'll find the same power can be acheived at lower boost levels Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-583707 Share on other sites More sharing options...
2fardown Member 526 Member For: 20y 10d Gender: Male Location: Brisbane Posted 12/10/07 12:08 AM Share Posted 12/10/07 12:08 AM I would say you're making 280rwkw at 14 psi, because that's your peak boost.To give you a comparison, I'm running 313rwkw (all dyno's are different) on the same boost of 14psi. Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-583714 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 9m 11d Gender: Male Location: Melb Posted 12/10/07 12:26 AM Share Posted 12/10/07 12:26 AM your standard actuator cannot hold boost up in the rev range.. that's why the boost comes in at 14psi, and then drops to 12psi...So, your making 280rwkw with 12psi boost..Post up your dynograph so we can better explain it for you.. Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-583722 Share on other sites More sharing options...
TOM1111 Member 631 Member For: 17y 9m 23d Gender: Male Location: newcastle Posted 12/10/07 04:36 AM Share Posted 12/10/07 04:36 AM you'll find that because your intake and exhaust is practically stock, the turbo has to work harder to produce those numbers, if you were to replace the car, a better cooler and some valve springs, you'll find the same power can be acheived at lower boost levelsthat's a bit extreme lolmy boost similar around 13-14 psi to make 268rwkw as evereything is stock apart from the injectors Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-583835 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 14d Gender: Male Location: SW Sydney Posted 12/10/07 05:49 AM Share Posted 12/10/07 05:49 AM sorry should've been cat duh! Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-583868 Share on other sites More sharing options...
Hyena Member 61 Member For: 18y 9m 2d Posted 13/10/07 12:44 PM Share Posted 13/10/07 12:44 PM your standard actuator cannot hold boost up in the rev range.. that's why the boost comes in at 14psi, and then drops to 12psi...Is that normal for the stock actuators to not be able to sustain boost above 12 PSI ?With a wog cooler and 3.5" cat my generic 8 PSI tune is now boosting to about 13 PSI most of the way through the rev range and the 10 PSI tune sustained 15 or over (I'm not running it until I get a custom tune next week) Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-584212 Share on other sites More sharing options...
tquarrell Member 181 Member For: 20y 9m 18d Gender: Male Location: Sydney, NSW Posted 14/10/07 06:02 PM Share Posted 14/10/07 06:02 PM The peak boost is the right number to quote imo, this is the maximum boost reached (any amount under maximum is irrelevant imo). FPV claim 9psi for the typhoon despite boost trailing to 6ish psi in the top end stock. Ford claim 6psi for the xr6t despite boost trailing to 4-5psi in the top end. For reference sake my car has 200rwkw stock, 263rwkw on 8psi, 281rwkw on 10psi and 299rwkw on 14psi. A freeflow cat probably won't make much difference until 9+psi so the higher the boost level the greater the effect of cats/exhausts/coolers on boost numbers Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-584455 Share on other sites More sharing options...
MYWPN Donating Members 554 Member For: 19y 10m 20d Gender: Male Location: Bendigo Posted 15/10/07 02:30 AM Share Posted 15/10/07 02:30 AM The peak boost is the right number to quote imo, this is the maximum boost reached (any amount under maximum is irrelevant imo). FPV claim 9psi for the typhoon despite boost trailing to 6ish psi in the top end stock. Ford claim 6psi for the xr6t despite boost trailing to 4-5psi in the top end. For reference sake my car has 200rwkw stock, 263rwkw on 8psi, 281rwkw on 10psi and 299rwkw on 14psi. A freeflow cat probably won't make much difference until 9+psi so the higher the boost level the greater the effect of cats/exhausts/coolers on boost numbersIt's based on what boost you are running at maximun power. say your boost curve tapers off and your running 14 down to 12psi top end (where max power is achieved) with 280rwkw if you were running 14 psi at maximun power your power level will be higher than 280rwkw, so its not really running 14 psi is it Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-584517 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 14d Gender: Male Location: SW Sydney Posted 15/10/07 02:51 AM Share Posted 15/10/07 02:51 AM cats and exhaust and intakes, are for efficiency so even if you don't up the boost much, with a freely flowing exhaust and intake the car will be much more responsive and feel quicker becasue of it... Link to comment https://www.fordxr6turbo.com/forum/topic/38959-boost-vs-rwkw/#findComment-584530 Share on other sites More sharing options...
