September 29, 200719 yr #1 hey im looking at lowering the t ute.. atm ive only got the stock 17inch wheels on, im eventually going to put 20s on.. my questions is if I lower it with the 17's will I need to change the ride height once again after the bigger wheels go on?! cheers nathan
September 29, 200719 yr #2 it should level itself out a bit, but if you go too low, the tyres will scrub inside the gaurds, so don't go too extreme, or wait until you get the 20's and do it all at the same time! Should look sweet though!
September 29, 200719 yr #3 What 20's you got in mind nathan? I'm sorta in the same boat, I got 18's on at the moment and I wanna drop it down 2 inch's at the back but I'm also looking at chuckin 19's or 20's later on.
September 29, 200719 yr #4 Author ah not too sure at the moment ive got a white ute and think black rims with machined lip go off on a white car so something along those lines but theyre another 8 weeks away yet I change my mind about the wheels daily..
September 29, 200719 yr #5 Author cheers senna yea I cant go too low as the 3 1/2" exhaust hangs real low.. I want the back of the car to sit just under the top of the tyre and the front just above it..
September 29, 200719 yr #6 ah not too sure at the moment ive got a white ute and think black rims with machined lip go off on a white car so something along those lines but theyre another 8 weeks away yet I change my mind about the wheels daily..As do I, yeah black looks mad on a white car.
September 29, 200719 yr #7 If you lower the car with 17's when you put the 20's on it will raise it abit, so id lower it when the 20's are on.
