September 12, 200719 yr #1 I'm now aware that my car is capable of 11 second passes, as I hit 120+mph down the 1/4 (only managed a 12.1)I just need some advice on how to get these things off the line and under a 2 second 60ftmy best was a 2.217.cheers
September 12, 200719 yr #2 Trade it for something with a clutch Na just kidding, stick some MT's on and drive it in perf mode... should piss an 11 in
September 12, 200719 yr #3 Trade it for something with a clutchmmmm, not a bad idea. 12.1 @ 120 is fairly ordinary Silouette.Even I was running 12.1 @ 116 & 12.3 @115 with my street tyres, with much less grunt.U want me to have a go??lolSeriously, nice times on our sh*te track. Turn up on a prepped track - world of difference.
September 12, 200719 yr #6 I'm now aware that my car is capable of 11 second passes, as I hit 120+mph down the 1/4 (only managed a 12.1)I just need some advice on how to get these things off the line and under a 2 second 60ftmy best was a 2.217.cheers120 mph your making good power,your 60 is a concern......not easy in the ZF With my tune the torque settings have not been touched so stalling in 1st gear results in zero boost no matter how much u stall it up The only way I could get the boost guage to budge was stall in 2nd gear and then flick back to 1st, I can only get a couple of psi this way which got me a 1.9 60HTH
September 12, 200719 yr #7 120 mph your making good power,your 60 is a concern......not easy in the ZF With my tune the torque settings have not been touched so stalling in 1st gear results in zero boost no matter how much u stall it up The only way I could get the boost guage to budge was stall in 2nd gear and then flick back to 1st, I can only get a couple of psi this way which got me a 1.9 60HTHHow does the engine rev yet produce no boost in 1st??? Edited September 12, 200719 yr by XRTPSI
September 12, 200719 yr #8 How does the engine rev yet produce no boost in 1st???In 1st gear once the turbine shaft is spinning u get boostIts in the software to save driveline damage Edited September 12, 200719 yr by F6BF
September 12, 200719 yr #9 get a decent tuner to mod your tune to get boost off the line... it now possible but there is plenty of goof ball tuners who have yet to catch up... 1.8 60ft has already been done in the ZF... UTFSE!C&V have done itBlueboost has done it...not sure about the others, but im sure there is more...
September 12, 200719 yr #10 120 mph your making good power,your 60 is a concern......not easy in the ZF With my tune the torque settings have not been touched so stalling in 1st gear results in zero boost no matter how much u stall it up The only way I could get the boost guage to budge was stall in 2nd gear and then flick back to 1st, I can only get a couple of psi this way which got me a 1.9 60HTHhey ive heard that u can put it into 2nd to stall it up and drop it back into 1st with the 6 speed auto, do you know if you can do it in the 4 speed auto too?
