  • Member For: 19y 5m 24d
Posted
hey guys.. just wondering if a EL xr6 is a good drive/buy. my sons after a first car and likes the look of them.... having never driven one personaly im just wondering if they are a good drive downfalls etc etc any help would be appriciated
  • Mad Scientist
  • Member For: 21y 10m
Posted
I used to have an EF, was just a falcon though, not an XR6 but it was a nice car to drive, I would reccommend one as a first car :roflmbo:
  • www.australianflag.org.au
  • Legacy Donating Member
  • Member For: 21y 2m 12d
Posted
They have poor brakes for such a large car, though not to hard to upgrade cheaply. Is it a manual or auto?
I had an EL XR6 and a EL XR8, loved them both.
Scotty
  • Member For: 20y 7m 14d
Posted
There are a good car. I used to have a white EL XR6. Make sure the cooling system is up to scratch though. Check for swelling around the top and bottom hoses and if the oring to the back of the water pump has been leaking. Leaking head gaskets were abit of a problem but easy to fix. The radiator tanks used to leak aswell.
  • Hench, but no longer shredded or tanned.
  • Member For: 19y 6m 1d
Posted
Mate as a young bloke myself (I'm 19) and having had an EL XR6 as my first car I can say they are great.
I never had a problem with mine, except for the brake discs (through my braking though)
Great first car to have, I'm sure your son would be happy with it also :roflmbo:
  • KILL,KILL,KILL,DIE,DIE,DIE,
  • Member For: 20y 4m 26d
Posted
yep I agree great first car, a few things to watch is like judd said the cooling system and if its done over 200ks ask if the head gasket has been changed if it has that's good as they usally go after the 200 mark.
  • Member For: 19y 5m 23d
Posted
great first car, id prefer a manual over an auto, atleast that way your son can do some burnouts, and there are some decent turbo kits for them aswell!
  • Member For: 23y 5m 3d
Posted
I had an EL XR8 with the full Tickford bodykit but it ended up stolen. Pricks. The XR6's were quicker than the 8's though, 15.1 down the quarter in manual form, they handle and drive quite well but as mentioned the brakes are pretty poor, but nothing a good set of slotted rotors and pads wouldn't fix.
  • Oh look.... a real car, with no hair dryer
  • Member For: 20y 1m 19d
Posted
Was & still is a great looking front end.
  • ride the lightning
  • Member For: 19y 11m 19d
Posted
I just sold 1.
if your young bloke is after a manual take care ..
have a real good look where the clutch cable goes through the firewall.
the ef/el have a big problem in this area .
splitting around the hole for the clutch cable and the metal on the firewall does split/when this happens you will have no clutch and will need to remove the brake master cylinder and weld a plate. to inspect the fire wall pull the sound deadning stuff off the fire walland have a good look.also they are prone to noise in the diff.if the car hasnt got coolant walk away.
