  • Member For: 19y 2m 29d
Posted
hey all. I piked up a used xr6t manual ute last week and ive been havin problems with idle after I give it some juice. it drops to like 250 then back up to 750. its got a ss cai but otherwise stock has anyone else had this problem? cheers in advance
  • RUS531
  • Legacy Donating Member
  • Member For: 20y 1m 9d
Posted
Is this when you are stationary and give a bit of a boot? Sometimes mine does drop the revs to the point where I think I might stall... I don't know if this is normal aswell mine is a xr6 NA 06 model so if anyone has any ideas I'm interested too... I'm no expert but I narrowed it down to the electronic throttle playin silly buggers
  • T.P.I.S.
  • Member For: 21y 9m 25d
Posted
Take off the piping and hammer some throttle body cleaner down it. Mine was like that for ages till I did this.
Try it and tell me what happens.
Posted
it happens after I give it a run then say stop at a set of lights. mine also goes so low it shutters and has stalled twice in the week that ive had it. I spoke to ford and they think it could be the cai but cant really explain how that would effect it?
  • Mmmmm......BOOST
  • Member For: 19y 5m 1d
Posted (edited)
[/quote
I don think cai does jack to cars basic running first up dont talk to ford find a good ford tuner mechanic in your area and talk to them
but yeh clean thottle body first and dont spray the cleaner straight down the body either spray a rag and wipe it out or remove it and clean it I have seen some real nasty manifold backfires from mates sprayin throttle cleaner into body and manifold
Edited by our06t
  • Member For: 19y 6m 19d
Posted
this used to happen to my ba n/a xr6, I took it to ford n they said the computer needed to be re configured, cost 45 bux, and since then its been ok. hope all goes well
  • T.P.I.S.
Posted
When the engine is off put your finger in the throttle body to open it up and spray. It will close once released. Then start it and it will stutter bad trying to run on the cleaner and after a few seconds slowly increase throttle a little then it should run smooth. No backfires from me.
Repeat if needed and all good after that.
I had the same problem, drive then come to a stop and it surges then once at a complete stop it comes level then after 10 secs it either tries to stall or stalls.
Mine has been great ever since.
Cant hurt to try just dont do it while its running.
Cheers
Adrian
  • Colossal Member
  • Member For: 22y 1m 4d
Posted
It is a common problem, and it usually takes a TB clean. Sometimes it needs a reflash/update (depending on when it was last done)
Mine hasn't done it since I got an edit
