Ninka Legacy Donating Member 1,850 Member For: 23y 9m 8d Gender: Male Location: Perth, WA Posted 25/05/07 01:03 AM Posted 25/05/07 01:03 AM I am betting on the flexplate, I hope it is for your sake.Pretty easy to check!Remove the plastic cover between the sump and transmission, and see if the flexplate moves when leveraged with a screwdriver or similar.If it's a rod, consider yourself lucky that it didn't break, as the engine can be rebuilt fairly cheaply provided nothing else is damaged.
xoression Member 2 Member For: 19y 4m 7d Posted 25/05/07 10:31 AM Posted 25/05/07 10:31 AM hopefully all will be revealed 2morro afternoon trent. I'll swing past work and grab the compression tester and maybe a scantool so we can do a power balance test
IEATV8S Member 354 Member For: 19y 7m 26d Gender: Male Location: Albury, NSW Posted 08/03/09 05:19 AM Posted 08/03/09 05:19 AM Old thread so I thought I would jump on it. I have the same problem I put the car on the ramps today to see if I had a loose flexplate I tightened all bolts none of them were loose. Im hopeing its not a rod I have 285rwkw 04 BA could it be the Torque converter? and is it okay to drive it to the Auto place or should I tow it. Anyhelp plz.
ETM Member 1,194 Member For: 19y 6m 19d Gender: Male Location: syd south Posted 08/03/09 06:22 AM Posted 08/03/09 06:22 AM You only tightened the flexplate to converter bolts, the ones that come loose are the flexplate to crank bolts and you need to remove the gearbox to do so.
IEATV8S Member 354 Member For: 19y 7m 26d Gender: Male Location: Albury, NSW Posted 08/03/09 06:39 AM Posted 08/03/09 06:39 AM ahhhh okay cool will have a look thanks mate
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 18d Gender: Male Location: Dé·jà vu Posted 08/03/09 07:09 AM Posted 08/03/09 07:09 AM Sounds like a flexplate or bolts gone, mine did the same thing.. sounded terrible driving down the return road!For those interested to learn what happened to the OP's car...
Ace blind leading the blind Member 3,657 Member For: 18y 21d Gender: Male Location: Mt Alford, Queensland Posted 08/03/09 07:18 AM Posted 08/03/09 07:18 AM it would be interesting
