01txr Member 861 Member For: 19y 8m 16d Gender: Male Location: QLD Posted 15/04/07 07:50 AM Posted 15/04/07 07:50 AM (edited) HiI would like to know how my tune maybe affected since I have fitted a X force system.Not ready for tune as wanting to fit a shorter intake track first and maybe purchase a Xcal 2.Car had the center muff removed prior to fitting X force, nizpro valve springs, walbro pump, hi flowed injectors and made 270rwkw hi oct tune and 250rwkw on soft tune both @ 12psi.Soft tune recorded mid 11 AFR's don't know hi oct AFR's.Car is 2003 may sedan 5sp manual.I have noticed it is making alot more power as it wheels spins 1st as soon as boost comes on and 2nd is on the edge pending road surface.Iam running 265 wide 19 Nankangs.Before this X Force exhaust was fitted it was doing same in first as what it is doing now in 2nd.Would this be close to its max with this system fitted now or would a retune extract a bit more?Also made a 307 VE R8 look like a HSV (Expensive Daewoo Slow Vehicle) today, what a buzz.Tried run through in 2nd on me at 60kph, I slammed 2nd with near instant rev limiter, hit 3rd pulled more than 2 car lengths before even getting to rev limit then braked.And that was with air con on, he may have to as his windows where up. Edited 15/04/07 08:00 AM by 01txr
MiKa Legacy Donating Member 4,243 Member For: 20y 1m 9d Gender: Male Location: Melbourne, VIC Posted 15/04/07 08:13 AM Posted 15/04/07 08:13 AM Im no expert but you should gain more once tuned so be prepared for more wheel spining lol.... HAHA love the story of the VE
RAPHOON Legacy Donating Member 1,776 Member For: 23y 3m 3d Posted 15/04/07 10:12 AM Posted 15/04/07 10:12 AM Based on my experience, a tune may be in order.My previous tune was made with a large dump pipe, cat and cetre muffler replacement. I had a 3.5" single Xforce fitted and it affected both boost and AFR's. Power was down a little as well.
silver ghost Legacy Donating Member 109 Member For: 19y 5m 30d Gender: Male Location: airlie beach Posted 15/04/07 10:20 AM Posted 15/04/07 10:20 AM I put a xfoce 3 1/2" system on mine the had to drive 140km to get tuned you have to watch it as your boost will climb to nearly 20 psi get it tuned asap youll love the diffrence mine is now 330rwkw bf xr6t
01txr Member 861 Member For: 19y 8m 16d Gender: Male Location: QLD Posted 16/04/07 03:40 AM Author Posted 16/04/07 03:40 AM Just hooked up boost gauge.Boost is 12 psi.When it is just warmed up and first WOT the boost is hitting 15psi and drops back to 12psi quickly.Boost readings are from BOV hose at x over, and gauge is a brand new cobolt Autometer.It doesn't ping or do anything stupid eg flat spots surging, but it does seem to be running rough at idle when cold but as soon as it reaches temp it settles nicely.
RAPHOON Legacy Donating Member 1,776 Member For: 23y 3m 3d Posted 16/04/07 07:04 AM Posted 16/04/07 07:04 AM Still a good idea to get the AFR's checked.
blueboost Member 1,204 Member For: 22y 4m 3d Gender: Male Location: Mackay NorthQueensland Posted 16/04/07 11:51 AM Posted 16/04/07 11:51 AM HiI would like to know how my tune maybe affected since I have fitted a X force system.Not ready for tune as wanting to fit a shorter intake track first and maybe purchase a Xcal 2.Car had the center muff removed prior to fitting X force, nizpro valve springs, walbro pump, hi flowed injectors and made 270rwkw hi oct tune and 250rwkw on soft tune both @ 12psi.Soft tune recorded mid 11 AFR's don't know hi oct AFR's.Car is 2003 may sedan 5sp manual.I have noticed it is making alot more power as it wheels spins 1st as soon as boost comes on and 2nd is on the edge pending road surface.Iam running 265 wide 19 Nankangs.Before this X Force exhaust was fitted it was doing same in first as what it is doing now in 2nd.Would this be close to its max with this system fitted now or would a retune extract a bit more?Also made a 307 VE R8 look like a HSV (Expensive Daewoo Slow Vehicle) today, what a buzz.Tried run through in 2nd on me at 60kph, I slammed 2nd with near instant rev limiter, hit 3rd pulled more than 2 car lengths before even getting to rev limit then braked.And that was with air con on, he may have to as his windows where up.just throw it on the dyno some where, some boost high, some are not so bad, but a quick dyno run will will check it all, and you might be able to leave it for a while, but its better to be safe then sorry.
