The NUT Member 163 Member For: 19y 28d Location: Townsville Posted 02/04/07 06:38 AM Share Posted 02/04/07 06:38 AM Boony 1981, im from Townsville too, and ford told me they tested mine when I brought it in and found the TPS to be faulty........ So im not quite sure whats goin on then, someone is lyin to us Nut Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-516426 Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 18y 2m 14d Location: Townsville Posted 02/04/07 10:26 PM Author Share Posted 02/04/07 10:26 PM Boony 1981, im from Townsville too, and ford told me they tested mine when I brought it in and found the TPS to be faulty........ So im not quite sure whats goin on then, someone is lyin to us NutI found out that Ford in Townsville can test the TPS but won't release the stats on it to other mechanics so that they can't test it. And I really don't want to take my car back into ford. Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-516693 Share on other sites More sharing options...
2fardown Member 526 Member For: 19y 11m 25d Gender: Male Location: Brisbane Posted 03/04/07 01:33 AM Share Posted 03/04/07 01:33 AM Why don't you ask a fellow Townsville resident if you could try their TPS to see if it fixes your problem? Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-516746 Share on other sites More sharing options...
LUMO Donating Members 476 Member For: 18y 2m 23d Gender: Male Location: SYDNEY Posted 03/04/07 10:16 AM Share Posted 03/04/07 10:16 AM hey guys read what I have written already if you could get a tps for free or borrow a mates one to test it then do it because I took my car to a mechanic and they said it was the #1,2 & 3 coil packs and the tps is not calobrating. hey dude I have a 2002 model manual and im having the same problem. ive changed the tps, 3 coil packs (it was the #1,2 & 3 coil packsthat came up on the diagnostics), done the solenoid and cleaned the sh*t out of the TB and still same problem. (tps and coils $300 later and still no change)on the diagnostics it says the "tsp not calobrating" I dont no what it means but ive been told the the tsp and your ecu are getting and sending the wrong readings eg if you to the floor with the pedal your ecu is reading that your at like 3/4 of the way on the pedal.I still havent taken it to ford due to being broke but ill be taking it to ford as soon as I get cash but if you find out what the problem is can you let me know please thanks, pete Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-516909 Share on other sites More sharing options...
mickey_gee Member 593 Member For: 20y 6m 22d Gender: Male Location: Newcastle NSW Posted 03/04/07 10:31 AM Share Posted 03/04/07 10:31 AM My car is doing the same thing. Can you get the fault out of the ECU if you have an edit??MG Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-516918 Share on other sites More sharing options...
Boony_1981 Member 32 Member For: 18y 2m 14d Location: Townsville Posted 04/04/07 04:30 AM Author Share Posted 04/04/07 04:30 AM My car is doing the same thing. Can you get the fault out of the ECU if you have an edit??MGThe fault codes should be the same with an edit. Unfortunately the problem doesn't always produce a fault code when reading the ECU. I'm having the problem and no fault codes came up when we diagnosed it. Even flashed it back to factory and still no fault codes being recorded. Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-517205 Share on other sites More sharing options...
1234me Member 54 Member For: 18y 4m 27d Location: Adelaide Posted 04/04/07 11:24 AM Share Posted 04/04/07 11:24 AM I had a problem with tps, the light was comming on sometimes. It ended up being the pedal assembly.Total job came to $950 becaust the tps has 2 parts, (engine bay and pedal, along with cables etc) I had everything changed. Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-517380 Share on other sites More sharing options...
scott81 Member 17 Member For: 17y 1m 13d Gender: Male Location: perth WA Posted 23/05/08 09:36 AM Share Posted 23/05/08 09:36 AM mine was doing the same would stall sometimes slowing to traffic lights(manual) took it to ford said no faults where coming up so they tighten the turbo and manifold bolts up and gave it a carbon clean. it was still the same. I read somewhere that you hold you foot flat when you start you car and the engine wont start then take you foot off than start it, its suppose to calibrate the tps not sure if this is true but the problem is gone now no more erratic rpm's Link to comment https://www.fordxr6turbo.com/forum/topic/33719-tps-problem/page/2/#findComment-680954 Share on other sites More sharing options...
