neil101 Legacy Donating Member 123 Member For: 20y 11m 8d Gender: Male Location: Kurrajong Heights NSW Posted 01/03/07 02:13 AM Posted 01/03/07 02:13 AM Has anyone thought of or try'd moving the battery accross (like they do on the turbos)and have the intake pipe coming over to the driver's side with a pod in an enclosed cai (like the turbos) sure it would be going over the exhaust manifold but it would be a smoother less interupted path.Whats everyones thoughts??Neil
Gavin.K Member 288 Member For: 21y 3m 8d Gender: Male Location: sydney Posted 01/03/07 02:18 AM Posted 01/03/07 02:18 AM What about the heat that would be obsorbed by the intake pipe fron the extractor??It would get heat soaked I feel??
neil101 Legacy Donating Member 123 Member For: 20y 11m 8d Gender: Male Location: Kurrajong Heights NSW Posted 01/03/07 04:24 AM Author Posted 01/03/07 04:24 AM (edited) I don't think heat soak would be that greater issue doesn't seem to upset the turbos that much, however once the car is moving and air is being forced in from behind the headlight I don't think it would be that much of an issue.The main thought behind it was to get rid of the big elbow to the throttle body that may cause some restriction.Neil Edited 01/03/07 04:24 AM by neil101
Guest Guests Posted 01/03/07 04:31 AM Posted 01/03/07 04:31 AM worth giving a go I think, heat soak is a killer in all cars mate, but we'll never know till some one trys it.Why not move your battery out hook up your CAI set up and whack in on a dyno, if it don't work put the battery back in.Sound like a fun test.
Guest Guests Posted 01/03/07 04:31 AM Posted 01/03/07 04:31 AM Only one way to find out. Give it a try and let the results speak for themselves
Guest Guests Posted 01/03/07 04:44 AM Posted 01/03/07 04:44 AM (edited) Talk to G&D about your idea, they want to get into N/A's and may help you with it.I think its another idea worth a look at, good luck and let us all know if theres some thing you need help with.We also have some guys in Team N/A that are very handy with pipe work, why not ask them? Edited 01/03/07 04:46 AM by NOS XR
FPV TRANNY Im the one and only Legacy Donating Member 3,557 Member For: 21y 8m 13d Gender: Male Location: In my house Posted 01/03/07 04:55 AM Posted 01/03/07 04:55 AM How about doing the plenum and having the throttle body coming the other way and putting the pod on the passenger side.No elbows or heat soak.
G6ET8U Playing with Sports Bikes... Legacy Donating Member 1,927 Member For: 20y 10m 22d Gender: Male Location: Whistling, GTX. Posted 01/03/07 05:36 AM Posted 01/03/07 05:36 AM Not my area of expertise, but have any of the N/A brigade tried a Nizpro plenum?I remember seeing a car at Nizpro at one of the dyno days that had a custom plenum on it... I think from memory it pulled around 200rwkw... it must have had cams and stuff to pull that kind of power but you never know it might be worth it... Anyone done it?I also remember seeing an old Skyline, R31, that had the factory RB30de (non-turbo) and it had one of the old school Nizpro VL Turbo RB30 plenums on it and Simon was saying it made for it's age, and the time some brilliant results...Jack
falconutebeast Member 196 Member For: 20y 4m 2d Location: Sydney, Bankstown Posted 01/03/07 08:33 AM Posted 01/03/07 08:33 AM How about doing the plenum and having the throttle body coming the other way and putting the pod on the passenger side.No elbows or heat soak. ←that's a good idea. only problem, you have to have someone with good welding skills.Not my area of expertise, but have any of the N/A brigade tried a Nizpro plenum?I remember seeing a car at Nizpro at one of the dyno days that had a custom plenum on it... I think from memory it pulled around 200rwkw... it must have had cams and stuff to pull that kind of power but you never know it might be worth it... Anyone done it?Jack ←there log plenum is $1500
G6ET8U Playing with Sports Bikes... Legacy Donating Member 1,927 Member For: 20y 10m 22d Gender: Male Location: Whistling, GTX. Posted 01/03/07 08:40 AM Posted 01/03/07 08:40 AM And that is pretty expensive if you don't get the gains out of it, but if you do, then the sky is the limit...As I said, I'm no expert on the N/A side of things, but you never know until someone takes the plunge...Jack
