  • Member For: 20y 8m 2d
Posted
Wondering if anyone has had this or could point me in the right direction.
When I pull on the the window washer stalk, my widers go, and only after a while does some water spray out of the left hand side jet. It seems the right hand side ( drivers)
is blocked? I have taken off the pipe from the resovoir to check the output
( into a coke bottle) and it seems fine..
And tips on whats happening and how to fix it?
  • BOOST
  • Moderating Team
  • Member For: 23y 24d
Posted
Get a fine pin and stick in the sprayer jets. Might be a bit of crap caught in them
  • Member For: 23y 9m 6d
Posted
What he said. Either that or drop it down to your local ford dealer and let them take a look for you
  • Member For: 22y 9m 13d
Posted
I have the same problem in the ute sometimes.
I found that it wasn't anything in the jet though. Sometimes the little filter on the pump gets clogged up with gunk and restricts the flow.
Possibly the one-way valve in the cowl panel is stuffed also
The bottle is in the worst place to check aswell.
  • Legacy Donating Member
  • Member For: 22y 7m 15d
Posted
If the pin trick does not work, you can undo the pipe from the washer jet and get a hose and put some water backwards through the jet to flush any crap out. I have found that if there is something a little larker than a pin hole, it will not be cleared with the pin trick, but a quick blast of water does the trick.
  • THE Member
  • Member For: 21y 2m 24d
Posted
It will be the filter for the pump in the bottle!! :spoton:
Chooka
  • ORSM Ford Cruisers!
  • Member For: 21y 3m 30d
Posted
Yeah the filter gets clogged by algae or some crap, constantly happens with mine, spose I should use cleaner water eh.
Matt
  • Member For: 20y 10m 16d
Posted
Mine did the same some how the line had kinked don't know how because it was behind the guard.
Posted
Any one know hoew to get to the water bottle filter thing your talking about, just spent f***n ages taking the air filter out ( dropped spanner down side )
and now its out looks like im going the wrong way?
Posted
Straight out of the Manual.
1. Remove the left front wheel
2. Remove the left front stone guard
NOTE: To prevent spilling windshield washer fluid, drain the windshield washer reservoir before
removal.
4. Remove windshield washer reservoir
1. Disconnect the electrical connector.
2. Remove washer cap from reservoir so that washer cap does not become obstructive at windshield washer reservoir removal stage.
3. Disconnect the washer hose from the washer-pump.
4. Remove the two bolts & nut.
5. Lower windshield washer reservoir from vehicle.
Hope it helps.
Matt
