February 4, 200719 yr #1 I have got a f6 it has got redcliff dyno ecu in it I have a problem with check engine light comeing on so I removed the ecu and now the car run rich does any one no y thank u
February 4, 200719 yr #2 Are you running a Edit Box as an ECU replacent aint as easy as you describe ........If you are have you had your injectors upgraded, .... you should not put your factory Tune in unless you have your OEM injectors in the railPs welcome to the forum Peteas for your oil light.... Cant help unless there is more info Edited February 4, 200719 yr by stealthxr
February 4, 200719 yr #3 Firstly, Welcome to the place.Secondly, it is very hard to determin the problem as you have not been very descriptive about what you have had done.I gather you have a RDP piggyback ECU that you have removed.IF you also had bigger injectors then the stock ECU will make the car run very rich.I would speak to Steve from RDP about your problem as he is very helpful and will have it sorted out quick smart.
February 4, 200719 yr #4 Agree wit Zap.Steve will rectify the issue for you but sounds like the injector have been replaced and hence the car would no be running VERY rich.
February 4, 200719 yr #5 Generally the check engine light only comes on from a TPS fault ( Throttle Position Sensor )On the throttle body, check the plugs ( x2 ) are connected properly..
February 5, 200719 yr #7 Welcome to the forums!Dont mean to sound out of line, but you probably should ask Steve the question before posting it up here mate. He is a great guy and should be able to sort it out without an issue.
February 5, 200719 yr #8 There's a few phoons with the same issue, talking from personal experience I was told it was the 02 sensor, it's an issue CAPA may need to assist the tuner with.
February 5, 200719 yr #9 Author There's a few phoons with the same issue, talking from personal experience I was told it was the 02 sensor, it's an issue CAPA may need to assist the tuner with.←It has all been sorted thanx guys for all your input what has been done is I spoke to the guys at redcliff dyno they where a great help .What they tell me what has been done is that the standard injectors have been hi flowed so that's y it is running rich so I going to fit a set of orginal ones today and see how we go thanx again Edited February 5, 200719 yr by mytyphoon
November 19, 200718 yr #10 I was just gonna say increase boost till its not rich hahaha just jokin good to see you got it sorted out
