  • Member For: 19y 9m 19d
Posted
I just had my 2004 4 speed auto ute tuned. It pulled 309 rwkw.
with my gtech I did a coule of quick 0-60 mph runs which the best was 4.8 seconds (34 degrees, very hot day)
With this sort of power what could I expect to run down the quater.
Is it true that if I had the same power behing a zf 6 speed that it would be a quicker car?
  • Replies 27
Posted Images
  • Seriously Flukey Member
  • Legacy Donating Member
  • Member For: 22y 6m 8d
Posted
With that power, you could expect anything from a low 12 to a high 11.
  • Im the one and only
  • Member For: 21y 8m 22d
Posted
With that power and the right setup,you could run mid 11,s.
Posted
what is the best way to set things up to run the best times,
I will probably be taking it to calder later this month
  • Member For: 22y 4m 3d
Posted
Full tank of fuel, some mt street radials, stall it up, and hang on,
should be good for a mid 11 with traction, as long as the tune has plenty of torque down low, it has not got a lot to do with your peak power, but what your average power. but these cars should be up around 119mph with that power.
a 6speed auto with your power at the flywheel, would have around 320rwks,
so it should run a bigger mph, but might be a bit slower off the mark with the mt radials, but would beat you with normal street tyres on both cars.
imo David
  • Next stage, to the Pub in 10 seconds
  • Member For: 22y 1m 16d
Posted
With my car running 297rwkw's at the time with stock intercooler, ran a
11.50 @ 120mph
Rob...
Posted
I have the following mods
wog cooler
deka injectors
cobra valve springs
k&n
typhoon CAI
3" metal cat (magnaflow)
the car currently puts out 309 rwkw
what would be the next step without spending too much
what is the limit on the pistons and rods in these motors?
I want to try to keep the stock exhaust as I dont like noisy cars
  • role model
  • Member For: 20y 6m 19d
Posted
wog cooler
deka injectors
cobra valve springs
k&n
typhoon CAI
auto or manual??
