Kimberley Scott www.australianflag.org.au Legacy Donating Member 6,763 Member For: 21y 2m 3d Gender: Male Location: Brisbane Posted 24/11/06 07:29 AM Posted 24/11/06 07:29 AM Where do you buy Transmax Z in Brisy, and where can I get it changed?I would like to do it tommorrow, I know it is a long shot, otherwise I will buy some and hit up Goldie.Scotty
937 Member 266 Member For: 20y 2m 17d Posted 24/11/06 07:39 AM Posted 24/11/06 07:39 AM SuperCheap Auto should have it.
Kimberley Scott www.australianflag.org.au Legacy Donating Member 6,763 Member For: 21y 2m 3d Gender: Male Location: Brisbane Posted 24/11/06 07:41 AM Author Posted 24/11/06 07:41 AM I will try both Supercheap and Autobarn in the morning.ScottyHow hard is it to do yourself?
Fat-Tony Legacy Donating Member 5,364 Member For: 20y 6m Posted 24/11/06 08:07 AM Posted 24/11/06 08:07 AM Where do you buy Transmax Z in Brisy, and where can I get it changed?I would like to do it tommorrow, I know it is a long shot, otherwise I will buy some and hit up Goldie.Scotty←After seeing those photos you I dont think Ian would mind you hitting on him
937 Member 266 Member For: 20y 2m 17d Posted 24/11/06 08:18 AM Posted 24/11/06 08:18 AM Get the car on to 4 stands so you can get under it.I made this filling tool a few years ago at work. Put the oil in, screw the top on and use compressed air. A bike pump will do You also need a 3/8 drive for the plugs.
Kimberley Scott www.australianflag.org.au Legacy Donating Member 6,763 Member For: 21y 2m 3d Gender: Male Location: Brisbane Posted 24/11/06 09:41 AM Author Posted 24/11/06 09:41 AM I will look at getting a mate to make up one of these out of an old Gas bottle. But until then I will just use a bloody big syringe.The only question I know have is, the reverse light, how does it work, as I would hate to screw it in to far and not gbe able to select reverse, or not screw it in enough and not have reverse lights.Hopefully the T is more high tech and this will not be an issue.Scotty
Paul@eliteauto Member 843 Member For: 20y 20d Gender: Male Location: Brisbane Posted 24/11/06 10:04 AM Posted 24/11/06 10:04 AM (edited) Get the car on to 4 stands so you can get under it.I made this filling tool a few years ago at work. Put the oil in, screw the top on and use compressed air. A bike pump will do You also need a 3/8 drive for the plugs.←If you fill them from the so called filler plug you WONT get enough oil into your gearbox. You need to put in 4 litres and you can only do it from the speedo drive.http://www.fordxr6turbo.com/forum/index.ph...e=post&id=26103 Edited 24/11/06 10:09 AM by Paul@eliteauto
RHR BOOST Moderating Team 5,698 Member For: 23y 15d Gender: Male Location: Southern Highlands NSW Posted 24/11/06 10:26 AM Posted 24/11/06 10:26 AM Sorry to addBut I had mine done today and it took ALL 4 Litres through the fill plug
937 Member 266 Member For: 20y 2m 17d Posted 24/11/06 10:30 AM Posted 24/11/06 10:30 AM I will look at getting a mate to make up one of these out of an old Gas bottle. But until then I will just use a bloody big syringe.The only question I know have is, the reverse light, how does it work, as I would hate to screw it in to far and not gbe able to select reverse, or not screw it in enough and not have reverse lights.Hopefully the T is more high tech and this will not be an issue.Scotty←Re how much oil.This man should know !http://www.fordxr6turbo.com/forum/index.ph...ndpost&p=468300I also use only 4 litres ! 937
Kimberley Scott www.australianflag.org.au Legacy Donating Member 6,763 Member For: 21y 2m 3d Gender: Male Location: Brisbane Posted 24/11/06 10:38 AM Author Posted 24/11/06 10:38 AM Dont worry I fully intend to only put 4 litres in. Wheteher it goes in thropugh the fill plug, or the reverse switch. I will find out tommorrow when I am under the car.Scotty
