  • www.australianflag.org.au
  • Legacy Donating Member
  • Member For: 21y 2m 12d
Posted
Where do you buy Transmax Z in Brisy, and where can I get it changed?
I would like to do it tommorrow, I know it is a long shot, otherwise I will buy some and hit up Goldie.
Scotty
Posted
I will try both Supercheap and Autobarn in the morning.
Scotty
How hard is it to do yourself?
  • Member For: 20y 6m 8d
Posted
Scotty
After seeing those photos you I dont think Ian would mind you hitting on him :roflmbo:
  • Member For: 20y 2m 26d
Posted
Get the car on to 4 stands so you can get under it.
I made this filling tool a few years ago at work. Put the oil in, screw the top on and use compressed air. A bike pump will do :roflmbo:
You also need a 3/8 drive for the plugs.
Posted
I will look at getting a mate to make up one of these out of an old Gas bottle. But until then I will just use a bloody big syringe.
The only question I know have is, the reverse light, how does it work, as I would hate to screw it in to far and not gbe able to select reverse, or not screw it in enough and not have reverse lights.
Hopefully the T is more high tech and this will not be an issue.
Scotty
  • Member For: 20y 29d
Posted (edited)
If you fill them from the so called filler plug you WONT get enough oil into your gearbox. You need to put in 4 litres and you can only do it from the speedo drive.
http://www.fordxr6turbo.com/forum/index.ph...e=post&id=26103
Edited by Paul@eliteauto
  • BOOST
  • Moderating Team
  • Member For: 23y 24d
Posted
Sorry to add
But I had mine done today and it took ALL 4 Litres through the fill plug
Posted
Scotty
Re how much oil.
This man should know !
http://www.fordxr6turbo.com/forum/index.ph...ndpost&p=468300
I also use only 4 litres ! 937
Posted
Dont worry I fully intend to only put 4 litres in. Wheteher it goes in thropugh the fill plug, or the reverse switch. I will find out tommorrow when I am under the car.
Scotty
