  • Member For: 19y 10m 24d
My understanding from on here was everytime Ford Flash your car you put that updated flash straight back in to your edit box and delete the old Ford one. You will have the latest one everytime.....am I wrong?????
When the Flasher box first Reads your PCM, it stores that code version. If ford flash a newer one on, the Flasher box WILL NOT update the "stock" code in the box.
That means, if ford updated your code in your PCM, and on your next service you return it back to "stock", you are infact downgrading your code back to the original one stored on the box.
Ford Service centres cannot see the changes in the "tune", they can only see the catch code from the wds etc. So if they see it has gone backwards compared to whats stored in their computer records aganst your car.. that's a instant alarm bell to its been flashed.
Danny.
  • Replies 211
  • Team Grandpa
  • Member For: 19y 2m 4d
See what you mean Danny, the debate is whether you can overwrite the stock one with the "new stock one" Was told you could by simply deleting it and loading the new stock one Ford just put in......maybe they were wrong....could have sworn it was a tuner on here though
  • Member For: 19y 8m 10d
There was a thread on AFF last month on this subject, it end up being removed as the thread starter asked for it to be taken off.
They say the BA is safe.
He said his mate is a Ford Master tech that has just done a training course, Ford now have a scanner called "ORACLE" that can be used on any suspect warranty claim to retreive any piece of information the pcm has stored since the vehicle has been manufactured, it can tell if the vehicle has been fitted with a tuner, what maximum boost level has been reached, what maximum rpm was reached etc etc:
  • Member For: 19y 3m 14d
it all comes down to the point, DONT TRY AND STOOGE FORD. if you break your motor cause you are running 300rwkw stiff sh*t, wear it you pay you play, I just dont like how ford make other non related warrenty work more difficult becuase of this one modification.
  • www.australianflag.org.au
  • Member For: 19y 11m 17d
Shock if you know Ford have flashed your pcm, you need the flash code. You then need to go to your tuner and get that base could put in your box and modify it, then put t back in your car. That way Ford cant tell. At least this used to be the case, from what I am reading it is no more. Ford have stepped up to the plate and tuners are going to have to get smarter. Or people will just have to accept the fact that if you mod, Ford will know and bing dada boom no more enginge and drive train warranty.
scotty
  • My new toy
  • Member For: 22y 2m 12d
Posts that were not on topic have been removed.
Ian
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 22y 12d
But Pete, you couldn't even find a permanent power source for Jeff's SatNav. Want me to give you to give you some hints, no certificate required here mate.  :shocked:
Good on ya :fool: Pete DID'NT fit my sat nav :pinch:
  • Big Gun
  • Member For: 22y 8m 24d
yeh, we know.....pmsl.
  • Member For: 19y 4m 28d
But Pete, you couldn't even find a permanent power source for Jeff's SatNav. Want me to give you to give you some hints, no certificate required here mate.  :stirthepot:
Good on ya :spit: Pete DID'NT fit my sat nav :smilielol:
Im still waiting for him....
