  • role model
  • Member For: 19y 1m 28d
Hey Guys
I'am curently about to upgraded my sound system and wanted to know
what size the speakers are at the front and back, and who has upgraded the sound system and did you have to buy a new head unit ???
Some help would be good thanks
Carlos... :laughing:
Edited by Black ThundeR
https://www.fordxr6turbo.com/forum/topic/26100-sound-system-upgrade/
  • Replies 38
  • Member For: 19y 1m 18d
front and rear speakers are a 5x7 oval speaker, mate who does installs tells me he has been able to get a 6 inch split in the front doors, mid range driver in door and tweater in the pillar, and a 6x9 in the back. Also upgraded the decks in these things by placing one where the power outlet and tissue box are and bypassing the stock deck, depends on how much you want to hack up your car will depend if a deck is that importnant to ya.
Cheers Adam
  • role model
so you can fit a 6" at the front I wasnt sure if you called but thanks mate
im also gonig to put 2x 10 or 2x 12 alpine subs in the back but ive been told
that I can keep the oringal head unit and just run it of a amp that true????
Carlos :spoton:
  • TerriGhia
  • Member For: 19y 3m 17d
I used a set of Fusion 5X7 splits in the front doors.these fit straight in.6 inch splits will need an adaptor plate.
I used the standard head unit with hi-lo line converters to run an amp for the subs.
this is a bit of a compomise as the sound quality is not as good as it would be with a good head unit and rca leads.but I still wanted to use the steering wheel controls,and it looked stock.All hidden.
  • role model
yer that kool I wanted to do something like that aswell but I wana
fit 2x 10 in the back but I wanted good quality bass and sound
but that not achiveabel wtih your set up is it?
  • TerriGhia
if you just want some boom,then it will be ok.If you want really good sound quality then I would say no.
It was ok for me as I dont drive around with the stereo up flat out.moderate levels ok.
if you want a killer system,change the head unit.
you can always try it,and get a head unit later.the hi-lo converters are not expensive,maybe $20.00.give it a go.
what do other people think?
  • role model
ok kool thanks
like im not gonig ot use the stero full blast all the time but when I wana
play some musix I wanna u know lol you want it to sound good lol
but I tihkn for me I just get a new head unit and some good RCA cables and good amp and I should be sweet lol
thanks for the help
Carlos :spoton:
  • Fastest Taxi In Melbourne
  • Member For: 19y 1m 29d
have a look at the asl logistics option
http://www.asllogistics.com/ford_upgrades.html
they can do a low level output that allows you to add an amplifier to your existing head unit. im pretty sure it produces far better quality than the high to low converters.
