RIC21T Member 22 Member For: 19y 2m Posted 01/05/06 10:36 AM Share Posted 01/05/06 10:36 AM Hey guys I want to put the F6 tachos on my xr6t. if I buy the " Ford Racing Tacho Driver" to suit a BA XR6 Turbo. will this Converts signal from factory loom to suit the bost and oil presure tacho’s. and is it had to wire them up?Thank you Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/ Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 19y 1m 15d Gender: Male Location: Hunter Valley Posted 01/05/06 10:43 AM Share Posted 01/05/06 10:43 AM shoot me down in flames if I'm wrong, but you can only buy these gauges if you have a FPV Vin no and they are a separate unit for wiring. Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376405 Share on other sites More sharing options...
RIC21T Member 22 Member For: 19y 2m Posted 01/05/06 10:48 AM Author Share Posted 01/05/06 10:48 AM I already got them from a mate that works for ford. but what about the is I get Ford Racing Tacho Driver loom from Herrod will this work? Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376411 Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 19y 1m 15d Gender: Male Location: Hunter Valley Posted 01/05/06 10:55 AM Share Posted 01/05/06 10:55 AM Not sure fella. I take it you mean the F6 gauges for the dash. Saw them on ebay for $425 which I thought was over the top + the actual gauges and wiring cost $$$ I'm sure someone can help you, pretty cluey lads on here.... Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376413 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 22d Gender: Male Location: Perth Posted 01/05/06 11:00 AM Share Posted 01/05/06 11:00 AM Hey guys I want to put the F6 tachos on my xr6t. if i buy the " Ford Racing Tacho Driver" to suit a BA XR6 Turbo. will this Converts signal from factory loom to suit the bost and oil presure tacho’s. and is it had to wire them up?Thank you ←The xr6t's and f6's use a "can bus" (whatever the hell that is) to drive the tacho and dash gauges as far a i know the oil pressure and boost guages on an F6 are a standard electrical gauge. The tacho driver WILL NOT help you at all. It's designed to take the Can Bus tacho signal from the ECM and convert it to a 5volt square wave signal that a normal aftermarket tacho (ie autometer)can read.hope this help.... Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376416 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 20d Gender: Male Location: Victoria Posted 01/05/06 11:03 AM Share Posted 01/05/06 11:03 AM If your just trying to hook up the FPV oil and boost pressure gauges there's some posts around here that will help. Is that what your trying to do?If so I'll see if I can dig them up. Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376419 Share on other sites More sharing options...
FSIX Member 566 Member For: 19y 7m 21d Posted 01/05/06 01:05 PM Share Posted 01/05/06 01:05 PM The Ford racing tacho driver is for running an after market taking on a BA OR BF these 2 models don't have a tacho signal to plug in for a after market tacho. If you use this tacho driver from Ford racing you can connect any after market tacho up to your ba or bf.Part No: Ford Racing Tach driver 17361-A200Herrod Sell them for $175, or you can buy them direct form Brisbane Ford racing distributor for $122.I also have a 2 page word document on instructions if anyone is interested. Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376504 Share on other sites More sharing options...
FPV329 Member 128 Member For: 19y 11m 9d Posted 01/05/06 10:27 PM Share Posted 01/05/06 10:27 PM There's an aussie made RPM module for our BA's available on eBay for $120.00 that has 2 pc/laptop user settable trigger points allowing a trigger for water spray or NOS and another trigger for a shift light etc.I've had one for around 6 months now and they're great, well made by a name you would all know but I probably can't say it because of sponsor rules.Just thought I'd get a plug in for the aussie unit! Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376593 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 9m 21d Gender: Male Location: Perth, WA Posted 02/05/06 12:07 AM Share Posted 02/05/06 12:07 AM Dunno why you would want an after market tacho... the stock one is surely big enough Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376608 Share on other sites More sharing options...
Bain Member 827 Member For: 20y 3m 17d Gender: Male Location: Melbourne Posted 02/05/06 01:11 AM Share Posted 02/05/06 01:11 AM Dunno why you would want an after market tacho... the stock one is surely big enough ←Fuuullly siiik people need them..Also gives you +25hp if you combine it with an aftermarket shift light.. and its orange. Link to comment https://www.fordxr6turbo.com/forum/topic/25101-ford-racing-tacho-driver/#findComment-376622 Share on other sites More sharing options...
