MercuryT Member 53 Member For: 21y 1m 18d Gender: Male Location: Melbourne Posted 20/04/06 08:26 AM Posted 20/04/06 08:26 AM For the last 6 weeks or so I had an intermitent engine mis-fire. When I had my EDIT done last week and we fitted new plugs the mis-fire seemed to disappear. Anyway since Monday the problem has returned and seemed to be getting worse! Cold morning starts were terrible, in to netural at the lights and a high idle with the car coughing and spluttering. I spoke with Simon @ NizPro and he advised me to bring the car back and he would look at a few things. We replaced all 6 coil packs, still no good, checked the spark plug gap again, all .08. We put the standard Ford tune back in and the car was terrible, noticably worse than with the EDIT tune in. Anyway, I took the car back to Westpoint who have been doing my service and have had several goes at determing this problem and they said "Sorry, can't look at until Friday week the 28th" That was over 10 days away, the car was running on 5 cylinders, gulping fuel and just being a horror to drive. Not Happy Jan! Anyway, spoke to Simon and he suggested Etheridge in Ringwood, so booked it in yesterday and took the car down this morning. Explained what Simon had done and also that he suggested it was probably the coil driver so they looked straight at the PCM. Did some tests and found the coil driver stuffed, this had also fried #6 coil pack!!! Changed the PCM and the coil pack. The new PCM is a newer harware & software version. This new version then wouldn't talk to the transmission. It kept throwing a code, anyway they ended up downloading the old file from another customers car and putting it in my new PCM. (They couldn't use use my PCM file as the driver was stuffed) The boys at Etheridge did a great job and the car is now beautiful again. So I leave and then try and reload my EDIT. The long and short of it is because the Processor number on the PCM has changed the EDIT needs to be reset!! Just lost a life! Anyway, Dave spends an hour or so trying to manipulate the file to work with the new processor number but the engine is just not happy. So anyway back to NIZpro in the morning for a re-tune!! I will let you know the end result.
asromanut Member 50 Member For: 23y 3m 29d Location: Melbourne Posted 20/04/06 10:58 AM Posted 20/04/06 10:58 AM sh*t man, any idea what caused this? If your going to be at nizpro tomorrow ill see you there.. im getting my custom edit done regardsMark
MercuryT Member 53 Member For: 21y 1m 18d Gender: Male Location: Melbourne Posted 20/04/06 11:08 AM Author Posted 20/04/06 11:08 AM Everybody is at a loss to explain why this has happened. It confirms to me that Simon is super switched on with the BA/BF product as he said to me that he thought it was a Coil Driver issue. This turned out to be exactly the problem. He suspects some other cars are affected with this issue but until they completely fail like my car, it is very hard to trace. The problem started very small for me, with only the occasional mis-fire but then went rapidly down hill in the last few days. The boys at Etheridge said that they had only seen 2 or 3 cars with this problem. Anyway, the car is sweet again, looking forward to getting the tune back into it.Catch you tomorrow.Simon
MercuryT Member 53 Member For: 21y 1m 18d Gender: Male Location: Melbourne Posted 21/04/06 02:47 AM Author Posted 21/04/06 02:47 AM So, I had my car re-tuned this morning and the results continue to improve!!The car made a little over 260 RWKW but ran out of injector and valve spring so Dave turned it down a bit and I ended up with 257RWKW. I will post the graphs when I get a chance but the car is fantastic again. Thanks NizPro!!
geea Site protagonist Legacy Donating Member 4,320 Member For: 23y 4m 25d Gender: Male Location: At the lights, waiting for you. Posted 21/04/06 02:59 AM Posted 21/04/06 02:59 AM that's a great result. Going from your results and the results from guys with BF Typhoons, I'm thinking that the BF Typhoon must have a bigger injector to be able to get around the 290rwkw area with standard injectors.Geea.
gogo Member of team Kittens Member 609 Member For: 22y 7m 13d Location: Melbourne Posted 21/04/06 03:47 AM Posted 21/04/06 03:47 AM that's a great result. Going from your results and the results from guys with BF Typhoons, I'm thinking that the BF Typhoon must have a bigger injector to be able to get around the 290rwkw area with standard injectors.Geea. ←
MercuryT Member 53 Member For: 21y 1m 18d Gender: Male Location: Melbourne Posted 21/04/06 03:48 AM Author Posted 21/04/06 03:48 AM I actually spoke with Dave about that exact issue this morning and he said that they had flow tested a set of BF Typhoon injectors and they flow exactly the same as a T. He had no idea how they are getting the fuel out of them. I am sure somebody will be able to shed light on how FPV are making them work!!
GOLDIE My new toy Legacy Donating Member 5,344 Member For: 23y 5m 14d Gender: Male Location: stanthorpe wine capital of qld. Posted 21/04/06 04:59 AM Posted 21/04/06 04:59 AM Not sure but I think the fact that although both the ba and bf run the same fuel pressure the fuel pump it self is a lot different in that the bf pump delivers almost double the fuel pre 10 sec test cycle than the ba pump.This may have something to do with it.Ian
MercuryT Member 53 Member For: 21y 1m 18d Gender: Male Location: Melbourne Posted 24/04/06 11:40 PM Author Posted 24/04/06 11:40 PM Attached is a copy of the New Dyno Graphs after my new PCM was fitted.The car is still fantastic. It seems to get better and better all the time
69ADY Member 85 Member For: 21y 3m 28d Location: Sunny Coast, Qld Posted 25/04/06 02:31 AM Posted 25/04/06 02:31 AM Not sure but I think the fact that although both the ba and bf run the same fuel pressure the fuel pump it self is a lot different in that the bf pump delivers almost double the fuel pre 10 sec test cycle than the ba pump.This may have something to do with it.Ian←If that is the case.... do you think that by changing the fuel pump in a BA to a BF type(if possible...), that you would not have to change the injectors and valve springs when going for a power upgrade edit under say, 280rwkw?Do we know what the max power output is for BA valve springs?And if possible to do, does anyone know the rough price of a BF pump?Just curious guys.. Cheers Adrian
