  • Bored Member
  • Administrator
  • Member For: 23y 10m 22d
Posted
how hard is it to get power from the cig lighter, can you access it by just taking the side panels off? I'm going to install mine tomorrow and I need a 12v source for the oil pressure gauge. should I be buying 'special' wire for the engine bay so it doesnt melt? :spoton:
Kaine
Pop the shifter cover off (not sure how with auto :stirthepot: ) , unscrew the 2 small side pieces pull them out then unscrew the tissue box holder, pull it forward and the cig wiring's on the left.
  • XR68UZ
  • Legacy Donating Member
  • Member For: 20y 8m 27d
Posted
wheres the tissue box holder? my tissue box is totally squashed from the back seat
  • Member For: 22y 7m 22d
Posted
next to the power source
It is below the ICC, its the 1/2 DIN spot you most likely put your mobile phone.
I do not think Ford put the tissues there anymore as I did not get them.
  • XR68UZ
Posted
my tissue box cant fit there. spoton, that's exactly where I put my phone :D
  • HgAg soldier
  • Member For: 23y 2m 23d
Posted
okkkk well I am finally almost done!! Took the ICC out to run the wires from the cig lighter, worked out well as the dash illumination could also pull from this point.
Gauges are hooked up and lights work, now all I need to do is connect the t-peice to the BOV..
So just to confirm, where exactly does it plug into? post-1503-1145768407_thumb.jpg
Thought this was going to be an easy mod but dammn wish I paid someone to do it!!
Any help appreciated,
Thanks
Kaine :pinch:
  • Member For: 21y 2m 12d
Posted
that tube going to somewhere scary is what you tap the t piece into, I did and it is very accurate
cheers
matt
  • HgAg soldier
Posted
Thanks Mac,
All connected now and working beautifully.
Cheers
Kaine :pinch:
  • XR68UZ
Posted
pics please? and also instructions if you have the time.
  • Member For: 21y 6m 12d
Posted
Here is a picture of my installation.
I did a couple of mods to the mod yesterday - added a switch for the mixture gauge so it can be switched off, and a 12volt power socket (for either a radar detector or a g-meter thingy)
I also added some stainless bolts, as I didnt like the cheapness of self tapping screws. Not sure if these look better or not?
I ended up using the back one of the screw/bolt holes to put the 12volt socket (the back is held tight with the boost fitting anyway).
  • HgAg soldier
Posted
I'll post a how to guide once I finish installing my oil sender.
Kaine
