Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 1d Gender: Male Location: Dé·jà vu Posted 07/03/07 12:57 AM Author Posted 07/03/07 12:57 AM Enviroment its a big word isnt it...
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 1d Gender: Male Location: Dé·jà vu Posted 07/03/07 01:07 AM Author Posted 07/03/07 01:07 AM You wouldnt believe the amount of photo's I go through to bring this crap to you....
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 1d Gender: Male Location: Dé·jà vu Posted 07/03/07 01:09 AM Author Posted 07/03/07 01:09 AM You Cant Park There!
tab Sucker Moderating Team 32,303 Member For: 22y 4m 21d Gender: Male Location: Brisbane Posted 07/03/07 02:17 AM Posted 07/03/07 02:17 AM Enviroment its a big word isnt it...←Yeah...those cooling towers pumping out all that steam are terrible aren't they
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 1d Gender: Male Location: Dé·jà vu Posted 07/03/07 07:37 AM Author Posted 07/03/07 07:37 AM Wheels let it down a bit...Lotec SiriusEngine: Mercedes 600 V 12 Position: Mid-engine System: V-12 engine, 48 valve, double Turbo Cylinder capacity: 5987 ccm Bore x stroke: 98,0 x 80,2 Compression ratio: 8,5 : 1 Valves: 4 per cylinder Turbo charging: 2 special KKK Turbo charger K 27 Intercooling: twin air - air intercooler Lubrication: drysumplubrication Cooling: water Performance / horse power (variable): 0.85 bar boost: 1.000 h.p. at 6.300 r.p.m. 1.20 bar boost 1.200 h.p. at 6.300 r.p.m. Performance / KW (variable): 0.85 bar boost: 735 Kw at 6.300 r.p.m. 1.20 bar boost: 882 Kw at 6.300 r.p.m. Max. Torque: 0.85 bar boost: 811 lbf ft at 3400 r.p.m. 1.20 bar boost: 974 lbf ft at 3400 r.p.m. Acceleration (km/h): 0 - 100 at 3.8 sec.0 - 200 at 7.8 sec. Top speed: V - Max up to 400 km/h (optional transmission) Tachometer: up 400 km/h Brake system front: Brembo ventilated racing disk brakes with ABS Brake system rear: Brembo ventilated racing disk brakes with ABS Gearbox and power transmission: 6 speed manual gearbox from CIMA, synchronized limited slip differential, transmission oil cooler Motor-Management: LENZ Turbo-Tronic, www.lenz.de Suspension: Independent front and rear suspension with unequal length upper and lower A-arms, coil springs, tube shocks, anti-roll, bars and power steering. Racing power brake system including ABS Tires and Rims: 3-piece Works-Rim with9,5 x 19" 255/40 ZR 19" front13 x 19" 345/30 ZR 19" rear Exterior and Interior: Free choice of colours and interior finishing, Instrument panel with circular type instruments, rev. Counter, speedometer up to 400 km/h., middle console with display for several indication functions, air conditioning, velour carpeting, sport seats and three point safety belts. Tinted glass fitted as standard. Full leather upholstery optional. Dimensions and Weight: length: 4.120 mm width: 2.080 mm height: 1.120 mm ground clearance: 80 mm curb weight: circa 1,280 kg
mbjunior99 Member 4,359 Member For: 23y 8m 23d Gender: Male Location: Brisbane Posted 07/03/07 07:47 AM Posted 07/03/07 07:47 AM I'll have one of them thanks
SCRIBR Yaris member Member 4,486 Member For: 20y 2m 25d Gender: Male Posted 07/03/07 09:25 AM Posted 07/03/07 09:25 AM iv got a pic of that things engine running at full tilt on an engine dyno.. if I cbf later ill dig it up!
mbjunior99 Member 4,359 Member For: 23y 8m 23d Gender: Male Location: Brisbane Posted 07/03/07 11:23 PM Posted 07/03/07 11:23 PM
mbjunior99 Member 4,359 Member For: 23y 8m 23d Gender: Male Location: Brisbane Posted 07/03/07 11:24 PM Posted 07/03/07 11:24 PM
Dagabond Bored Member Administrator 35,722 Member For: 23y 10m 1d Gender: Male Location: Dé·jà vu Posted 08/03/07 01:15 AM Author Posted 08/03/07 01:15 AM Fckin Ooops....
