  • Replies 28
  • Member For: 20y 9m 3d
It's obvious your not a canberran, here you wouldn't be waiting for 2 weeks time to tell ford...
its a beuatiful day in Canberra today :diggit: its not too cold yet
but it might get a wee bit wet.
  • TerriGhia
  • Member For: 19y 3m 23d
A few Ba's are getting stray currant(volts in the watar)
this can chew through radiators and heater cores in a mater of weeks.
:blink:
Sorry mate, its funny hearing someone trying to explain electrical principals. Sounds like someone has been feeding you :pooh:
Entertaining though :blink:
ask a radiator joint about stray currant.usualy comes from a bad earth on one or more eletrical curcuits.any more than .5 volts can be a problem.
spoke to our radiator suplier about a stock BA xr8 which had gon through 5 radiators.fixed by fittin a copper core radiator and running earth straps from the radiator to the chassis.
  • Colossal Member
  • Member For: 20y 8m 21d
The problem is they are radiator specialists, not electronics technicians. The phenomenon you are thinking of is similar to the way a battery operates, and is caused by 2 different metals in an electrolyte causing erosion (this also can happen on a boat).
Has nothing to do with electrical circuits nearby... and doesnt necessarily get fixed by an earth strap. The best way is to either change the type of metal used (ie same metal all the way through) or by fitting a saccrifical annode :blink:
  • TerriGhia
no,you can get currant in the water.evey time we buy a radiator it comes with instructions on how to test for it.its real and its out there man!
  • fordxr5turbodotcom
  • Member For: 21y 7m 5d
My heater no longer works, I have noticed no other symptoms/problems.  Whats likely to be causing this?
Looks like a service is due...esp since Canbrrrrrrrra winter is due in a few wks.
I currently have the exact same problem and wil DEFINATELY be telling ford in about 2 weeks time when the 30,000k service is due. :spit:
Bizarre I have the exact same problem atm too.. 75K service happening soon for mine though :kissmy:
