  • Colossal Member
  • Member For: 22y 1m 12d
Posted
Well I'll be buggered...
Can't really see for the heat shielding in the way, but looks like there are 2 pipes directly out of the stock cat. You would need to get a splitter made up (or purchase to suit) to go from the cat into 2 pipes.
When I get it done eventually I will probably get the Cat installed, then split into 2 to replace the centre muffler and have 2 hotdogs to join to the stock system. This will give me the sound I want and remove SOME restriction.
  • Member For: 21y 10m 22d
Posted
the stock cat is a single inlet from the dump and a single outlet, then branches off to a twin set up, I will post a pic when I get it off the camera
  • Legacy Donating Member
  • Member For: 22y 8m 5d
Posted
that would be great!!
  • Colossal Member
Posted
Are you sure?
I just looked at it under the car and it looks like 2 come out of the cat. If you could get a pic without the heat shields on it would be great :laughing:
  • Team Xtreme
  • Member For: 21y 7m 28d
Posted
Dump is single in and the rear of the cat is dual out into the zorst
  • Colossal Member
Posted
Looks like 2 out of the cat...
Have you taken off the heat shield?
Posted
not really any need, get the new one made up the same length, and from the cat into 2 pipes so if you ever need to put the stock cat back on it will be a direct fit
  • Member For: 23y 3m 9d
Posted
As many who have been around for a while will know, Exotic Exhaust in Brisbane make a direct bolt-on centre muffler replacement.
We've arranged for Exotic to fit Jet's Metal Cat to the standard dump pipe and centre section (whether one of their replacement units or the factory muffler). This will happen early next week.
They also mentioned that they will make a jig so that these units can be made to order (and sent anywhere in the country).
We'll keep you all posted. :spoton:
