  • Member For: 20y 11m
Posted
Well, I had the car tuned at FIST again and they managed to get 241rwkw out of it. Well, it lasted all of 1 day and now as soon as I put my foot down and the car reaches the 4000rpm line, the engine starts to ping its *beep* off! WTF????
My mods are as follows:
K&N Filter
2nd CAI
Edit
Centre Muffler Removal
968 Injectors
Valve Springs
Shift Kit
I am only sitting at 241rwkw, I would have thought I would be fine at this stage.
Do I need to have it retuned? Do I sell it? I had better luck with my Hyundai!
Any suggestions would help.
Rob.
  • Replies 72
  • Member For: 21y 11m 6d
Posted
Sounds like you need to go back and see the boys at fist I would have thought 241 was a little on the low side with the mods you mention could be a problem elsewhere maybe!!
  • Legacy Donating Member
  • Member For: 22y 7m 29d
Posted
sounds low for your mods... was there any reason given for the figures?? seems like your car wont play ball.... there has to be an underlying issue somewhere that we have not been told??
good luck in getting it sorted :spoton:
Posted
what plugs are you running??
  • Resident golf buggy drift champion
  • Member For: 20y 11m 11d
Posted
I see a trend here and it all leads to the same place...
Take your car elsewhere and see what they can do...if they get more power and better (Safe) results then we all know what the problem was.. if the same result is acheived then its your car....maybe it was built after a ford piss up at the factory..
Its worth a go..Bob Romano or Herrods maybe...The brock shop did almost as good with your car when it wqas standard with just an edit..
Its the only way you can narrow it down...
Maybe send your edit to WA and give it to Simon at Extreme hes done it B4
Dave
  • Team Xtreme
  • Member For: 21y 7m 22d
Posted (edited)
Guys there is just one mod missing from this list that I can see as being a big problem with the end power figure. Unfortunatley when you retain the stock cat it will keep power down, when the tuner tries to wind up the power because the figure is down it can lead to pinging and a heat build up in the engine(gases cant get out). All of the mods done are pointless if the car cant breathe!.
Replace cat with a good one watch that figure jump up. minimum 15 to 20 rwkw's.
BUT get a retune after
hope that helps
Edited by Xtreme F6
Posted
hope that helps
see he knows his SHHIIITTT unlike some tools
Sorry had a few bourbans and cant believe that after all the $ and parts spent only at 240kw...
Dave
  • Mushroom
  • Member For: 22y 4m 15d
Posted
hope that helps
I said this to Rob in a PM on the weekend when he mentioned his mods and where he was hoping to get to.
Rob......change the fuggin cat FFS!!! :spoton::spoton:
Posted
hope that helps
How can a lot of other people get much more than 240 with alot less and standard cat then???
Im interested to know as im going down a similar path
Dave
  • - Track Bound EVO III -
  • Member For: 21y 9m 15d
Posted
I doubt the cat is the restriction at that power level. Simon himself has extracted 271rwkw from an xr6t with only 968's, nothing else, so case in point. I fail to see why he has now changed his modification criteria??
300rwkw untill cat replacement I thought was the general concesus??
