turbotrana Member 2,586 Member For: 22y 2m 8d Gender: Male Posted 18/01/06 02:56 AM Share Posted 18/01/06 02:56 AM The Turbo setup Ford did is a poor design in the first place. Whatever you can do to reduce heat anywhere helps, but I think for any worthwhile gains in the heat department a Nizpro type manifold entry point is needed with the compressor outlet going to a front intercooler and airgoing across the car to the nizpro located inlet point. Link to comment https://www.fordxr6turbo.com/forum/topic/22698-heat-soak/page/2/#findComment-336800 Share on other sites More sharing options...
CnC SportCompact.biz Member 328 Member For: 22y 2m 26d Location: Canberra Posted 18/01/06 03:38 AM Share Posted 18/01/06 03:38 AM Some thoughts please.Whenever I come home from driving the T I automaticaly see how hot theintercooler is and always it is cool or at worst slightly warm. Recently I lifted the bonnet and found that the hose between the IC and the throttle body wasvery hot and the longer the car sat the hotter it got.Surely this is detrimental to have cool air from the IC and hot air to the throttle body. I realize that there is heat soak from the engine which heats up the hosethe longer it sits but if you are taking the car to the drags and sitting in line burnouts..etc, surely the hose must be producing warm air which is not good.It seems to me that the Cobra system where the hose goes straight into the plenum would be the most efficient as there is no heat soak in the hose as itis on the other side of the engine away from the heat.I dont want to go changing the system that I have now and have a question.Would wrapping the hose in header wrap make any difference, or would I be waisting my time and money?Any thoughts would be appreciated. Thanks, Bill.PS...I bought this subject up before but was'nt sure if I mentioned header wrap. <{POST_SNAPBACK}>The Cobra system is superior most definitely due to the reduction in surface are of the intercooler piping that is exposed to heat sources. The other obvious benefit is the dramatic improvement in throttle response. I have had a ride in the Nizpro workshop car that is running this system and the improvement is highly noticable.I am planning on getting one of these fitted myself in the next few months. Link to comment https://www.fordxr6turbo.com/forum/topic/22698-heat-soak/page/2/#findComment-336813 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 7m 17d Location: Auckland Posted 18/01/06 08:00 PM Author Share Posted 18/01/06 08:00 PM <{POST_SNAPBACK}>The Cobra system is superior most definitely due to the reduction in surface are of the intercooler piping that is exposed to heat sources. The other obvious benefit is the dramatic improvement in throttle response. I have had a ride in the Nizpro workshop car that is running this system and the improvement is highly noticable.I am planning on getting one of these fitted myself in the next few months.<{POST_SNAPBACK}>I agree, I reckon this is the best system for keeping heat away from your pipes.Even if it is a slight difference it must be good.I am aiming for around 300-315rw,if I was looking to go higher I would spend the money and get one I would like to see how you get on. Link to comment https://www.fordxr6turbo.com/forum/topic/22698-heat-soak/page/2/#findComment-337127 Share on other sites More sharing options...
