  • Moar Powar Babeh
  • Legacy Donating Member
  • Member For: 21y 15d
Posted
Hey guys here a dyno sheet from the tune Simon from Xtreme did for my ute...the top pink line is the Simon's tune, the lower red line is a tune that i payed somebody else a fair bit of money to do for me and the difference is pretty clear!!
Simon's tune make aprox 215rwkw at 2400rpm and just keeps climbing till it hits 300!!!
the other tune doesnt hit 215rwkw till around 4000rpm!!
Simon's tunes peak torque is aprox 800nm the other tune peaks at 605nm's! the car is incredible now it just flys!!
i cant say enough good things about simon nothing is to much trouble for this guy and the results of his tuning are awesome the guys a genius!!
  • Replies 27
Posted Images
Posted
Hey guys here a dyno sheet from the tune Simon from Xtreme did for my ute...the top pink line is the Simon's tune, the lower red line is a tune that I payed somebody else a fair bit of money to do for me and the difference is pretty clear!!
I cant say enough good things about simon nothing is to much trouble for this guy and the results of his tuning are awesome the guys a genius!!
<{POST_SNAPBACK}>
THE SHEET BUDDY THE SHEET?
  • Member For: 21y 6m 14d
Posted
So what mods do you have to achieve that power? ie Injectors, pump, cooler etc?
  • Member For: 22y 4m 12d
Posted
Lucus1 - what mods are you running m8?
  • Moar Powar Babeh
Posted
all the usual bits and pieces. aps exhaust pwr cooler. injectors valves springs and an eboost 2. the magic is in the tuning. was making a whole let less power than it is now and was just drinking fuel like it was going out of style. It's a whole different car to drive now.
  • Member For: 21y 4m 26d
Posted
So when the last tune was done you had EXACTLY the same mods & fuel?
  • Moar Powar Babeh
Posted
<{POST_SNAPBACK}>
yeah mate. only ever run bp ulitmate from the one servo so the fuel is about as consistent as u could hope for. everything else is exaclty the same
  • Member For: 22y 3m 29d
Posted
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
What boost are you running now compared to before?
  • Moar Powar Babeh
Posted (edited)
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
<{POST_SNAPBACK}>
same boost. 16psi
simon took a heap of fuel out of the tune in the bottom and midrange. the car was over fueling before which was costing it a heap of power.the two runs on that chart where done yesterday. the bottom one is the old tune that was in my flasher and the top one is simon's tune. he finished fine tuning yesterday
edit: sorry forgot to mention on the old tune it was overboosting up to 18 psi if you loaded the motor up in top gear. ie planting your foot in 4th to pass on the highway and it would surge down low. the boost comes in strong now and doesnt over boost or surge.
Edited by Lucus1
