gotxr6t Member 56 Member For: 21y 1m 13d Location: Sunshine Coast Posted 25/08/05 10:41 PM Posted 25/08/05 10:41 PM (edited) Only have 200kms on clock, but I think that the power seems to be inconsistent. say cruizing at 3000 rpm in 2nd and floor it, she will pull hard. couple minutes later say do the same again and the power dose not seem to be there. Is it just me or has any one else experienced it. I think it may have some thing to do with fly by wire. Would a flash tuner fix it? Edited 25/08/05 10:42 PM by had08
Macktheknife Xtreme Xalted Member Legacy Donating Member 3,112 Member For: 23y 4m 23d Gender: Male Location: BrisVegas Posted 25/08/05 11:04 PM Posted 25/08/05 11:04 PM Only have 200kms on clock, but I think that the power seems to be inconsistent. say cruizing at 3000 rpm in 2nd and floor it, she will pull hard. couple minutes later say do the same again and the power dose not seem to be there. Is it just me or has any one else experienced it. I think it may have some thing to do with fly by wire. Would a flash tuner fix it?Only a couple of hundred K's? Dont use huge long throttle belts just yet. Run in hard by all means but dont go overboard. It will get a lot better as things loosen up and your first sevice will be a good opportunity to get any little items checked up.Good luck.
Paradoxx Colossal Member Member 5,049 Member For: 22y 1m 4d Gender: Male Location: Perth, WA Posted 25/08/05 11:18 PM Posted 25/08/05 11:18 PM The car doesn't respond too well to temperature. After a bit of a blat the engine does warm up a fair bit and will rob you of power a bit while it's warm. This is overcome by plenty of moving air but if your sitting at the lights it heats up real quick.
cobrav8 Member 1,969 Member For: 21y 6m 5d Gender: Male Location: New Zealand Posted 25/08/05 11:31 PM Posted 25/08/05 11:31 PM They are more consistant in NZ as it is freezing all year around!
Bain Member 827 Member For: 21y 7m Gender: Male Location: Melbourne Posted 25/08/05 11:35 PM Posted 25/08/05 11:35 PM Check your hoses.Mine had come off 3 times in as many days when I first bought mine.They put 2 ring clamps on the hose to hold it.
gotxr6t Member 56 Member For: 21y 1m 13d Location: Sunshine Coast Posted 26/08/05 12:06 AM Author Posted 26/08/05 12:06 AM Nothing wrong with making engine work, (not talking bounching off rev limiter), you just don't let engine stay at same rpm for long period of time to run engine in.
Antisocial Weird Member Member 1,347 Member For: 23y 7m 25d Location: ACT Posted 26/08/05 02:44 AM Posted 26/08/05 02:44 AM They are more consistant in NZ as it is freezing all year around!<{POST_SNAPBACK}>...or Canberra.Car said it was 3 deg outside on the way to work this morning....woooohooo!
Swanga Benzene Member 432 Member For: 22y 3m 25d Gender: Male Location: Out West Posted 26/08/05 06:29 AM Posted 26/08/05 06:29 AM Mines done 3500kms and I find it to be inconsisten at times too but I think its just a heat thing
Trough Lolly Member 4,349 Member For: 22y 20d Gender: Male Location: Mildura Posted 26/08/05 07:50 AM Posted 26/08/05 07:50 AM wait till the engine breaks in first mate, of course theres gunna be odd moments but that's just the bedding in process!
Shockwave-T Member 96 Member For: 21y 3m 3d Location: Melbourne Posted 26/08/05 11:47 AM Posted 26/08/05 11:47 AM Mine has just over 1000km now and I notice this as well - There's a hesitation at about 3500-4000RPM (feels a bit like a slipping clutch, but I know the clutch isn't slipping if that makes any sense?) and it feels really flat above about 4500RPM as well. I have a mate who works at a dealership and he told me at the first service (3000km) they reflash it and this should hopefully fix the problem. So going by that, maybe there's some dud software out there?Thoughts?
