Engine To Put In Your Falcon
Featured Replies
#2
Hmm, wouldn't be a bad alternative, would it?! :msm::msm:
572 cubes and 720hp though, I can't imagine how much juice, tyres, etc, it'd chew its way through - I'd need a second job just to keep it on the road!! :gooff::fool:
#3
that was awesome! bloody huge that thing.
#4
For the same money I would..
-Buy two BA I6 heads..
-Go get a alloy block casted of a V12 60 degrees, using falcon bore spacing, bore, stroke, etc etc etc
-Machine said block
-Equipe with strong pistons and rods and custom crank
-Tune and map with aftermarket ECU
-Cams, porting, valves and springs for the I6 heads
Say hello to your 8.0L QOHC QVCT 48 Valve V12 pushing over 400 naturally asperated Kws to your rears.. Place this engine in a Fairmont Ghia body with a 6 speed and suitable brakes/clutch/shafts.
Okay, it would cost maybe $50,000... But then again I would imagine that engine wouldn't be cheap either.. Say $100,000 all up.. Nice little package.
#5
-Machine said block
I think I have seen it in those 'Parts Trader' mags, from the importer for around 25 or 30,000? (Australian)...
I THINK :spoton:
Lumpy :spoton:
#6
  • Author
The motor in my Cobra started life as a GM crate motor - LS7 454 - produced over 500hp out of the box. They are certainly great bang for bucks motors. Ford have Ford motorsport crate motors too - I think you can get a 600hp version of the Boss motor somewhere.
I would say the 20,000 price would be about the max - they are probably much cheaper than that.
Edited by cobrav8
#7
How much does your cobra weigh?
I think the problem with the xr6T isnt the motor its the weight of the car... :laughing:
#8
What the ?
Goes to show just how far behind the GM boys really are.
Downdraft Cabies, with a DIZZY ?
Please boys into the 21 century please.
Fuel injection has been around for about 25 years now on performance engines hasn't it ?
And if they want it to RUN, it really should be running a coil per plug.....
Ferrari and BMW probably produce the same horses out of 3 litres...
#9
  • Author
Cobra weighs just over 1000kgs, and yes, the Falcon is a bit overweight.
It would be interesting to see how much weight can be saved with kevlar panels etc (like BMW do by the way on the limited edition M3).
Granted - injection is a better way to go - more power, and more efficiency at the same time, but..... more complicated, it is nice to work on a car that you can do everything yourself. Also - for the amateur guys - the carb is much cheaper.
My car is kind of a mix between the two - it has Hillborn injection - huge big butterflys per cylinder - enormous power - but drinks petrol like mad, runs too rich at low throttle positions.
Anyway - none of ius would put one of these in a Falcon - just thought you might like a look on the other side of the fence.
Here is a pic of my fuel injection system:
Recently Browsing 0
