YOOT Member 1,201 Member For: 23y 3m 11d Location: Birkdale Posted 30/05/05 07:52 AM Posted 30/05/05 07:52 AM That would explain why my clutch may be on its limits then, I have 256rwkw at 5000rpm, and I'd say its just starting to let go at 4000rpm in 3rd, or is that axel tramp? Cause the wheels weren't spinning and something was shuddering slightly and the revs were rising faster than the car was accelarating for a split second.
TRELO Member 21 Member For: 21y 8m 28d Location: Merrylands , Sydney Posted 30/05/05 09:08 AM Posted 30/05/05 09:08 AM My ute has just over 300rwkw , the clutch just lets go at 3000rpm and gives up haha . Picking it up tomorrow with a twin plate brass
jetute Legacy Donating Member 4,553 Member For: 22y 7m 29d Gender: Male Location: brisbane Posted 30/05/05 09:37 AM Posted 30/05/05 09:37 AM My ute has just over 300rwkw , the clutch just lets go at 3000rpm and gives up haha . Picking it up tomorrow with a twin plate brassIs yours a phase 2 kit only??... or do you other mods as well??
TRELO Member 21 Member For: 21y 8m 28d Location: Merrylands , Sydney Posted 30/05/05 10:00 PM Posted 30/05/05 10:00 PM My ute has just over 300rwkw , the clutch just lets go at 3000rpm and gives up haha . Picking it up tomorrow with a twin plate brass<{POST_SNAPBACK}>Is yours a phase 2 kit only??... or do you other mods as well??<{POST_SNAPBACK}>Nah , I have other mods as well. I went for a customized job instead of a phase 3 kit
cobrav8 Member 1,969 Member For: 21y 6m 6d Gender: Male Location: New Zealand Posted 30/05/05 11:18 PM Author Posted 30/05/05 11:18 PM So what is the all up price of the brass clutch?
jetute Legacy Donating Member 4,553 Member For: 22y 7m 29d Gender: Male Location: brisbane Posted 31/05/05 08:46 AM Posted 31/05/05 08:46 AM My ute has just over 300rwkw , the clutch just lets go at 3000rpm and gives up haha . Picking it up tomorrow with a twin plate brassIs yours a phase 2 kit only??... or do you other mods as well??Nah , I have other mods as well. I went for a customized job instead of a phase 3 kitok... makes sense
6speedXR8 Mal Wood Automotive Member 537 Member For: 23y 6m 12d Location: WARWICK QLD Posted 31/05/05 12:36 PM Posted 31/05/05 12:36 PM This question is a very tough one, As you know Mal Wood Auto has done a huge amount of development with Tremec Transmissions and these transmissions continue to astound both Ben and Myself with the amount of HP or KW that these will take.I will give you firstly a comparison between the Late model camira T56 and the ford T56.The Tremec t56 as used in the Late model camira has ratios of 2.66,1.78,1.3,1.0,.74,.50. It runs a 26 spline input shaft and a 27 spline output shaft.The T56 as used in the XR6T has ratios of 2.66,1.78,1.3,1.0,.80,.62. It runs a 23 spline input shaft and a 31 spline output shaft.We have a Transmission running the same ratios as the Ford in a vehicle used in competition with 1022 engine HP and it is handling it ok.BCL's transmission was prepared and fitted by us about 12 months ago it has the same ratios as the new Ford.The bottom line is I very much doubt if a Turbo Ford 6, even a highly modified one would break one of these transmissions.The only damage that seems to have occured in some cars is directly contributed to clutch issues, ie the clutch not releasing properly or clutch drag.I have extensively tested our 11'' steel flywheel and 11'' single plate clutch and it has proven to the best option( in my opinion) for the Turbo 6 with a T56 transmission, we have had these in cars with in excess of 300rwkw.We have also developed 2 twin plate combinations for serious road/race application. Mal Wood
cobrav8 Member 1,969 Member For: 21y 6m 6d Gender: Male Location: New Zealand Posted 31/05/05 11:59 PM Author Posted 31/05/05 11:59 PM Cool - so gearbox is good for mods - type of answer I like to hear!What about your 11 inch clutch and flywheel - what kind of ballpark price are you looking at for the items? (I am in NZ so would install myself).
fordboy1981 Legacy Donating Member 2,076 Member For: 23y 8m 12d Gender: Male Location: Melbourne, Vic Posted 01/06/05 01:34 AM Posted 01/06/05 01:34 AM This question is a very tough one, As you know Mal Wood Auto has done a huge amount of development with Tremec Transmissions and these transmissions continue to astound both Ben and Myself with the amount of HP or KW that these will take.I will give you firstly a comparison between the Late model camira T56 and the ford T56.The Tremec t56 as used in the Late model camira has ratios of 2.66,1.78,1.3,1.0,.74,.50. It runs a 26 spline input shaft and a 27 spline output shaft.The T56 as used in the XR6T has ratios of 2.66,1.78,1.3,1.0,.80,.62. It runs a 23 spline input shaft and a 31 spline output shaft.We have a Transmission running the same ratios as the Ford in a vehicle used in competition with 1022 engine HP and it is handling it ok.BCL's transmission was prepared and fitted by us about 12 months ago it has the same ratios as the new Ford.The bottom line is I very much doubt if a Turbo Ford 6, even a highly modified one would break one of these transmissions.The only damage that seems to have occured in some cars is directly contributed to clutch issues, ie the clutch not releasing properly or clutch drag.I have extensively tested our 11'' steel flywheel and 11'' single plate clutch and it has proven to the best option( in my opinion) for the Turbo 6 with a T56 transmission, we have had these in cars with in excess of 300rwkw.We have also developed 2 twin plate combinations for serious road/race application. Mal Wood Great! how much?Dave.
6speedXR8 Mal Wood Automotive Member 537 Member For: 23y 6m 12d Location: WARWICK QLD Posted 01/06/05 11:50 AM Posted 01/06/05 11:50 AM My ute has 253rwkw,3.73 diff ratio,t56 6 speed and I drive it VERY hard ,it is the only way that we can test our products. The Steel flywheel and 11'' single plate clutch is our own design, we have had this clutch in cars with 390 rwkw and still going strong. Our clutch kits are continually being tested for overall performance, our option 1 flywheel and clutch kit to suit the turbo 6 costs $1250.We are fitting and testing our latest unit next week, I will post the results after testing. Mal Wood
