  • Member For: 22y 5m 21d
Posted
I dropped the oil in the T today and the oil I have been using is Fuchs titan supersyn 5w50 sl/cf. Ive since found out that fuchs have now changed it to titan supersyn 5w40 sm/cf. Now id prob prefer to have a 50 weight oil but im not sure what I should do. Should I change brands or is that a no no? any suggestions?
Shane
  • Here since the start...
  • Legacy Donating Member
  • Member For: 23y 5m 12d
Posted
Why are you using a 5W-50 oil?
There are many an arm chair expert running around here and have used all sorts of grades before so I'm sure you'll get a big variety of responses. For me I figure that Ford decided the XR6T needed 15W-40 for a reason so I'll stick to that.
Good luck with whatever you decide. :laughing:
  • Member For: 22y 7m 21d
Posted
Good luck with whatever you decide. :thumbsup:
I agree, Ford have chosen it for a reason.
From what I have found, don't go down to a 30 for ANY reason, but up to a 50 or 60 seems OK...but 40 is best for fuel economy..
Posted
Yeah I know everyone seems to have there own opinions on which oil to use etc,
but I was more interested on what people thought about changing brands or grades, I think ive heard that once your using a particular oil you shouldnt change
Thanks anyway :thumbsup:
Shane
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 13d
Posted
.....oops!
I don't think it would really matter that much though. The real fanataics change their oil viscosity to match the seasons so I wouldn't think it would do too much harm.
And what oil are you using Shane, it sounds like number 32 on the local chinese restaurant's menu?
Trent.
Posted
.....oops!
Trent.
<{POST_SNAPBACK}>
:thumbsup: it does a bit doesnt it
Posted
I can't see changing brands to be a problem.
Another interesting point is that in the Herald Sun's Cars Guide there was a letter from a guy asking what oil to put in his XR6N/A. They contacted Ford, and I'll be stuffed if I can remember what oil they recommended in that letter. But! As a side note they had also asked about the XR6T, and the answer to that I do remember and it was Mobil Super XHP 15W40. They went on to say that Ford don't recommend synthetic oil to be used in the XR6N/A and XR6T.
  • Member For: 23y 1m 5d
Posted
15w40 4 the T and 10w30 4 the na are the correct types from memory
I think it also specifys the low-vis type as well.
If we take into account brands
# redline boys recommend 15w50 for the T
http://www.redlineoil.com.au/oil-finder.asp
#Penzoil seems to be on the money 15w40
http://www.penzoil.com.au/?method=lubematch.lubematch
# Castrol GTX3 - 15w40
http://www.castrol.com/castrol/productdeta...ntentId=6008606
# Valvoline Problend 15w-40 or ENGINE ARMOUR 15W-40
http://www.valvoline.com.au/products_up.cf...Y&category=FO20
Who said oils aint oils! :thumbsup:
