  • Member For: 23y 11m 7d
Posted
Hi chasps... OK - MissT has just been in for her 30K service. All sweet. They fixed the exhaust rattle, tightened the front submember that was (apparently) loose and reflashed the PCM (even though I expressly asked them not too!).
Now they claim the front pads and rotors are worn below spec and must be replaced !!! after 30K !! are the rotors made of cheese ??? I ask you.
They ask $750ea for front rotors and $305 per set for pads - all OEM. total $1994ish. YIKES !!!
So I think to myself....'self' sure I can do this a little cheaper than that.
Today I surf PBR - Harrop - and any one else who comes up under google !
Any one on the forum care to offer some suggestions ?
Remember I'm South Australia based so any clever ideas that involve driving the car interstate will be daintily side stepped out of expediency...
cheers to the forum
  • FORD FORD FORD
  • Legacy Donating Member
  • Member For: 23y 6m 21d
Posted
Contact bcr01 for additional options
  • Member For: 22y 6m 8d
Posted
DBA 4000 rotors for you car part number 42104 will cost around $200.00 per corner probably less and look to ferodo for pads preferably DS2500 expect the same cost $200.00 per axle
DBA 4000 Catalogue
  • Flower Power
  • Member For: 23y 11m 28d
Posted
The DBA's would be more expensive for your car PuffnStuff as you got the premium brakes or at least I think you do.
I'm up to 42,500 on mine and I'll probably get a note saying my rotors need replacing at the 45k service (although the groove is still there).
I can save you money on the pads if you want. I have some genuine Ford Premium brake pads, the same ones they are going to give you. They have 1mm missing (they come with 7mm) as they've done 5,000 kms (mostly hwy).
Shouldn't cost too much to freight them down to Adelaide, and I'll let em go for $150 + freight (negotiable) if you're interested.
that's half the price you've been quoted for just 1mm worn.
  • Formerly Turbo6
  • Member For: 23y 9m
Posted
What Scotty said. I put on the whole performance kit from PBR and thus far are light years ahead of the OEM brakes. The track day next weekend will soon sort them out............
PM bcr01 for supply. :spoton:
  • Just sit back and enjoy the ride...!
  • Member For: 23y 1m 14d
Posted
Ditch the crapfest that are the standard brakes and put in a a set of PBRs. Cost me $1750 including delivery plus about $300 to install at my local Midas shop (with brand new Super DOT4 fluid). :spoton:
Posted
Just checking before I surf some more...
Thanks CRO for the offer. Give me another day or so to pursue some upgraded bits and bobs. If it all works out too expensive I may just take you up on your offer and throw them on with the original disks. Not a perfect solution as I like MissT to be just 'so'.
thanks all for the responses so far...
Posted
DBA 4000 Catalogue
<{POST_SNAPBACK}>
Not for Premium Brakes! That would be for the Standard T Brakes.
I can supply Pads and Rotors for both Premium and Standard Brakes
<{POST_SNAPBACK}>
I have been quoted $223 from repco for those discs last time I was looking around
  • CNUTOX
  • Member For: 23y 9m 2d
Posted
I was quoted 660 fitted price for dba slotted rotors, 325mm x 32mm with bendix ultimate performance pads. It was if I remember about 220 a corner for the rotors and about 180 for the pads.
  • Member For: 21y 5m 3d
Posted
I picked up DBA slotted rotors for the XR6t and Bendix Ultimate Brake pads
rotors $155/side..
pads $150/both sides... discounted from $205
total $460 for the front upgrade
installation $0
any monkey with a wrench can do it :censored:
