  • Member For: 22y 11m 7d
Posted
I waited months to save up for my edit, a few days ago I finally got it. Couldnt wait to download the 10psi map. Its faster yes but it surges like crazy, it backfires and it doesnt hold consistent boost. It boosts to about 13psi, drops to about 8psi and then if Im lucky it may hold boost at about 10.5psi. I downloaded the 8psi tune, its a bit better but it still spikes, surges and carries on.
I may give C&V a call and book in a much needed custom tune.
BTW I have 2nd cold air intake with panel filter and have removed the centre muffler.
Would re-gapping the plugs fix this, what dimension do you plug them to again?
The factory tune isnt so bad after all.
  • Replies 44
  • Seriously Flukey Member
  • Legacy Donating Member
  • Member For: 22y 5m 26d
Posted
2 Words - CUSTOM TUNE.
  • Member For: 21y 6m 24d
Posted
<{POST_SNAPBACK}>
Mine's the same!
Unfortunately, I live in Darwin... The prospect of getting someone to custom tune the Edit up here is non existant... :spoton:
If any Edit tuners out there are reading and feel like a holiday up North, it's really nice weather up here between May and September, I'm sure I could round up a few Edited cars to tune... call it a 'Business trip'!!!
  • loitering with intent
  • Member For: 23y 28d
Posted
Is it possible you got one of the first version of the magic box as these maps seemed to be more problematic , particularly the 10 PSI map ? Most seem to be ok now
Anyway , I would be getting onto the supplier and get them to sort it free of charge or get a full refund. As the guys said , for some piece of mind get a custom tune anyhow
  • Member For: 22y 7m 15d
Posted
gapping the plugs does fix it!!!!
gap to .89
I had the same on my previous T... gapped the plugs and all was fine.
I now have the new mark 2 T56 and plugged her in... coughs farts and splatters all over the place... I will gap the plugs and all will be fixed!!! EASY
gap the plugs and enjoy :laughrolling:
Posted
gap to .89
<{POST_SNAPBACK}>
Sweet... thanx for that! I'll give it a shot tomorrow.... I seem to remember someone saying on here to re gap the plugs, but they didn't give the specs!!!
Cheers!
If that doesn't work I'll speak to the retailer and try and sort it out there!
  • In Your Face
  • Member For: 23y 6m 7d
Posted
gap to .89
<{POST_SNAPBACK}>
Cheers!
<{POST_SNAPBACK}>
It's 0.9mm NOT .89mm :smilielol:
Posted
I can see how re-gapping the plugs will fix the surging but will it fix the overboosting?
Posted
where do you get the 13 psi from... was it dynoed?? or is that from a boost gauge..
Blown Ba... the stick I used was 0.89 :laughrolling: maybe the super cheap ones are a bit dodgy with inacurate figures :smilielol:
