March 1, 200521 yr #1 Iam thinking of adding CAI to my XR6T, Have been looking at the painted kits available from AWC. Have any of you guys fitted that type to your car or which way should I go with my choice. Edited March 1, 200521 yr by mathews80
March 1, 200521 yr #2 Do a search, there's heaps on here about CAIs. I have the xr8 pod with 2nd intake.
March 1, 200521 yr #3 Do a search, there's heaps on here about CAIs. I have the xr8 pod with 2nd intake.
March 1, 200521 yr #4 http://www.fordxr6turbo.com/forum/index.ph...topic=15262&hl=look here I tell ya this set up is fantastic...the reponse is great ..took about 30 min cheap I give it the
March 2, 200521 yr #6 I did the second intake using the XR8 snorkel that goes under the headlight and directly into the cold air box. Decent filter and Search and there are plenty of articles on this set up.
March 3, 200521 yr #7 I did the $40 special with the drain pipe adaptor and ford intake pipe under the headlight and have noticed quite a difference. It comes on boost a little earlier and the BOV doesn't seem to chatter any more, it sounds louder and more like a woosh. I just couldn't see the point in forking out 400 bucks for a simple attachment that doesn't even come with a bloody filter!
March 3, 200521 yr #8 http://www.fordxr6turbo.com/forum/index.ph...topic=15262&hl=look here I tell ya this set up is fantastic...the reponse is great ..took about 30 min cheap I give it the Yep, that's the go
March 3, 200521 yr #9 All you need is another hole that sucks clean and cool without giving you sh*te when you ask it to cook dinner...........Or else go to the threads mentioned
March 3, 200521 yr #10 Senor,is want fasts? I speak to you about recommend a piggyback computers. They are the fast! Do not tinkers with cold airs, is like cold fart. Trust me, is you want real powers to make the womans wet you are need Unichip or Exede or similar. Is then you real mans with pants that bulge.
