January 18, 200521 yr #1 My Avatar, which I 'borrowed' from someone else on the site wont animate.Its an animated .gif file which animates on my PC no probs, and was animated as an avatar elsewhere on this site.What could be the problem?I like em bouncing
January 18, 200521 yr #2 On uploading the image has appeared to be convered into a .jpeg which has no ability to animate. Try uploading it again.
January 18, 200521 yr #3 Author On uploading the image has appeared to be convered into a .jpeg which has no ability to animate. Try uploading it again.<{POST_SNAPBACK}>I have tried a number of time to re-upload.Never works :(Alan
January 18, 200521 yr #4 Author On uploading the image has appeared to be convered into a .jpeg which has no ability to animate. Try uploading it again.<{POST_SNAPBACK}>I have tried a number of time to re-upload.Never works :(Alan<{POST_SNAPBACK}>I have deleted and re-uploaded with a new name, still appears the same
January 18, 200521 yr #7 Author Needs to be uploaded as a gif animation!Russ<{POST_SNAPBACK}>What specifically does that mean?It IS an animated gif on my PC.There appears no options to select the type at upload time.Cheers,
January 18, 200521 yr #8 Most likely GD is resizing the image to suit forum requirements and saving it as a JPEG.
January 18, 200521 yr #10 I had the same problem.. unfortunately u need to SHRINK the size down to fit the dimensions if u want it to be animated...
