  • Legacy Donating Member
  • Member For: 22y 10m 18d
Posted
All,
have always enjoyed the old heel-and-toe method of down shifting...but have found this task a little harder to perfect in the T. This thread discusses the use of GT pedals and how they look...nothing about performance.
Although they look great, I would also be buying them for the extended accelerator pedal and side extensions.
The FPV site states "Alloy pedal covers with rubberised non-slip protection and side extensions make heel-and-toeing exercises easier. "
So...any T owners who have the rather highly priced GT pedals...your thoughts?
Anyone practice the heel-and-toe action with the standard T pedals? Am I just uncoordinated?
thanks
Chris
  • Replies 28
  • 00-XRG / 006-FPV
  • Member For: 23y 9m 27d
Posted
Hmmmm, this is something I've never done in any car, I don't think. I've just jumped off the brake to give the throtle a quick stab between downshifts.
Do you heel the brake and toe the accerator? or opposite?
Posted
Goose,
I go with the traditional method...ball of my right foot on the brake with the heel "blipping" the accelerator between gears...
just proving difficult in the T with standard pedals is all.
C
  • 00-XRG / 006-FPV
Posted
Have you tried bigger shoes??? hahaha jks, sorry back on topic.
  • Member For: 23y 1m 8d
Posted
What is the deal with the heal toe thing. Is it to give the the car a few rev's just before changing gears to make for a smoother down shift?
  • 00-XRG / 006-FPV
Posted
that's my understanding of it, to match revolutions of the engine to the gearbox.
  • Sucker
  • Moderating Team
  • Member For: 22y 5m 8d
Posted
Can't get it to work.
Do you think it's because I have an auto?
Wrong technique! You need to try toeing and toeing.
Trent.
  • 00-XRG / 006-FPV
Posted
Trent.
there's a minor problem, that generally rusults in this
Posted
Here's a description of the technique of Heel and Toe from a teacher at a
performance driving school:
Downshifting - In order to accelerate quickly out of a corner, the car
must be shifted to the appropriate lower gear before the corner.
Naturally this should be done as late as possible, preferably at the same
time that you are braking for the corner.
This presents a small problem. If you are braking and shifting, your
right foot is on the brake, and your left foot is on the clutch. Without
throttle input, the engine RPM's will drop quite low and when you let the
clutch out, you will 'pop' or jerk the rear wheels. This sudden jerk acts
as an additional brake, but could cause the rear wheels to exceed their
traction limit and cause a skid, to say nothing of the potential damage to
either the engine or drivetrain! The solution lies with heel-and-toeing. This technique during downshifting helps achieve smoothness,
while eliminating possible clutch slippage and extending the life of the
transmission.
Here's how it goes:
1) As you begin braking with your right foot, depress the clutch with your
left foot. (so far, just like normal). 2) With the clutch all the way
in, two things happen: move the stick shift into the desired lower gear,
and rotate your right foot so that the ball of your right foot is still on
the brake, and your heal is over the go go pedal. 3) Now "blip" the
throttle to raise the RPM's by about 1000 - this matches the RPM's. 4)
Now release the clutch, and ease off the brake.
I guess it is mainly used on the race track for maximum speed out of a corner and ensuring less chance of a rear wheel lock up, also taking care of your clutch, tranny, engine and drivetrain.
