messna
Legacy Donating Member
Everything posted by messna
  1. the inside diameter of the flex section compare to the std one is the same, the labour was expensive because it was difficult to get the right angle and weld but now they have made one I guess it will be easyier. Not sure on the standard items price.
  2. its was designed to handle the heat, and its a direct replacement for the low mount.
  3. its not cheap $250 the fittings and labour was the killer
  4. please comment on my new oil drain pipe, my old one cracked so I had a custom one made up.
  5. they have brought the window tinting laws the same as in every other state so we can go darker legaly.
  6. just got my self some tri-pod and gauges just wondering if there is any one in adelaide how has done it before and wants to install myn for cash? cheers
  7. cheers mate to go to the next level I need forged internals and a 6 speed, that's all happening next year.
  8. rapid v3 kit etm external waste-gate mod, turbosmart 45 pro-gate walbro fuel pump injecters from rapid nizpro valve springs SMB 4 inch exhaust
  9. take the turbo off send it to ETM to get the external waste-gate job do, had my done and its great. then put you turbo back in and drive it carefully to your nearest tuner. $900 odd for external waste-gate work from ETM $500 to 700 for retune or get more parts and then retune.
  10. rapid (his kits)
  11. if your planning to run 300 + upgrade to a 3.5 split or for 350 + get a 4 inch dump
  12. messna replied to a post in a topic in XR6 Turbo
    240 - 250 rwkw
  13. car transport Acr Australia 08 8395 0966, there good but expensive.
  14. HPF charge 795 and do a great job
  15. just bought a snort plenum, lol only if it was a few days earlyer. all well
  16. $930 in total and you send you rear housing to ETM, if you no how to use a spanner and socket its easy. there's threads on the site on how to remove the turbo.
  17. that's right,cant even see it with the exhaust manifold heat sheild on, fark the dose sound is loud with no BOV.
  18. almost finish, exhaust shop has to plumb the screemer into the dump.
  19. advanced systemcare professional
  20. will take more pics with the wastegate on on saturday, have to take of the heat shield on the engine mount.
  21. has anyone installed the external wastegate mod with the 45mm turbosmart wastegate yet, I have tried and the wastegate hit the engine mount and wont fit or am I missing a but. In the kit I got, 45mm wastegate screemer pipe rear housing with the new hole in it does the wastegate bolt directly onto the turbo or not. I have tried to ring etm and email but no responce. any help will be great. cheers
  22. messna replied to BLN68U's topic in General Tech
    .8 gap running on standed boost can it be done, as my gearbox is on its way out and I would like to put it back to stock.
  23. I have just bought some .8 gap spark plugs from repco for $ 22 each and installed my 10 psi tune, runs sweet as. cheers
