  • Member For: 22y 5m 1d
Posted
I found alot of rubber shavings at the front of the engine around the pulleys etc. I inspected the belt and found a thin layer of rubber on top of the belt was missing!
On closer inspection, sure enough the metal pipe just on top of the belt (to the left of the engine) was touching it and hence shaving the belt. Luckily there happened to be a clip (to pull the metal pipe away from the belt) but somehow was at positioned far away to the right which allowed the metal pipe to sag down and touch the belt. So I moved the clip to the left and problem fixed!
Here is a pic of the problem and fix. Hope it helps.
  • Forged Member
  • Legacy Donating Member
  • Member For: 19y 7m 9d
Posted
Hmmm, very useful info for the FG drivers :beerchug:
  • Member For: 19y 6m 29d
Posted
yeah same thing has happened to mine... now that I know why ill change the clip over to the otherside when I get home.. cheers for the info dude
  • It's not a MKI!
  • Member For: 18y 2m 28d
Posted
There should be two clips there guys. One at either end.
Mine have both come loose on the pipework and disappeared.
I have noticed, however, that both pipes are quite firm and don't seem to move at all with plenty of clearance to the belt.
It may be worth checking the mounting ends of the pipes for security.
Posted
Good point. Check the mounting also. Looks like these plastic clips come off easily. I better keep a metal coat hanger wire handy in the boot just in case this remaining clip falls off between now and the next service.
  • Member For: 23y 1m 11d
Posted
There has been a few reports of this happening. Hasn't done it on mine yet though.
Benny
  • Member For: 17y 11m 14d
Posted
same thing happend to me on my BF
  • Member For: 23y 2m 11d
Posted
I have seen this on a BA (may have been a BF, but Im 99% sure it was a BA) and it was just the same as what has happened here.
  • BOOST
  • Moderating Team
  • Member For: 23y 11d
Posted
Good find mate
  • Member For: 21y 9m 3d
Posted
Same thing happened to my FG, I didnt even notice till it went in for its First service and they replaced it
