MaStars Donating Members 81 Member For: 6y 10m 21d Gender: Male Location: The Gap, Brisbane Posted 13/06/17 03:22 AM Share Posted 13/06/17 03:22 AM Hi guys, So loving my New/old G6E Turbo. Been doing it heaps, forgot how much I missed Boost lol. However I have noticed something weird. My temp gauge never seems to reach half way on the gauge typically just 1/4 to 3/8. I live in QLD I know its a bit cooler at the moment but every car I have ever driven will always get to temp being half way on the gauge? Is this a normal thing? or would it be a faulty gauge? I have heard people mention something about a cold thermostat? is that a thing that would cause this? any help would be geat thanks guys Ben Link to comment Share on other sites More sharing options...
NathanB Member 136 Member For: 10y 11m 1d Gender: Male Location: Melbourne Posted 13/06/17 03:54 AM Share Posted 13/06/17 03:54 AM Yeah I know my bf sits between 1/4-1/2 and I've been told if it goes over 1/2 to check the cooling system out. Using the cal or obd2 scanner I can see it sits between 85-100 degrees even on 40 degree days down to super cold nights. The car does a bang on job of maintaining about 90 degrees. Sounds about right to me though unless someone knows more about the fg platform. Link to comment Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 16y 5m 29d Gender: Male Location: Perth Posted 13/06/17 04:10 AM Share Posted 13/06/17 04:10 AM (edited) 195F/91c thermostat temp will read just under half. 180F/82c temp will read just over 1/4. The reading is actually head temperature as the sender unit doesn't contact the coolant. Now that I run E85 and 82c temp stays on 1/4. Edited 13/06/17 04:11 AM by arronm Link to comment Share on other sites More sharing options...
Ezy2Confuze Member 898 Member For: 14y 6m 10d Gender: Male Location: West Perth. Posted 13/06/17 04:15 AM Share Posted 13/06/17 04:15 AM There was a conversation about this in I think it was the off topic thread & those ranges are basically normal.Some people have the non stock temp thermostat (108 farrenheight iirc) which their tuner installed. I bought my G6ET with basically XFT's stage 1 package which had the gapped spark plugs, ID1000 injectors, XCAL 3, "cooler thermostat" & tune already done by the previous owner.However the first thing I did was get it checked over & serviced & was told the thermostat was leaking.So I emailed XFT & was told by them what thermostat to get & the seal part number, as it could have been either thing that was faulty. I got both because it cost lest than $30 for both, so really cheap insurance.Just an additional tip or two, Ford apparently don't ever change the diff oil, so I would get that done plus maybe get the fuel filter changed depending on the age & K's of the car. 1 Link to comment Share on other sites More sharing options...
MaStars Donating Members 81 Member For: 6y 10m 21d Gender: Male Location: The Gap, Brisbane Posted 13/06/17 04:56 AM Author Share Posted 13/06/17 04:56 AM ok thanks guys. I dont know much about the history, I know its got full service history but not any other modifications, seems 100% stock to me. perhaps it has a 82°c thermo and that's why it sits just above 1/4 all the time? I have an OBD2 BT reader thing I will throw it on tonight and check it out good tip on the diff oil, when getting rwc I got my mech to check the diff fluid he said it was still full but didn't say if he thought it needed replacing. he did say there was a bit of seepage around the front seal. but wasn't an issue as it looked old, he will monitor and check again next service 5k away I believe. as for fuel filter that is a good point I will check that out its got 145k on the clock. thanks guys. Link to comment Share on other sites More sharing options...
