05/04/26 05:09 AM05/04/26 05:09 AM #1 I have a FG Mk1 G6E that is a write off. Can I fit the indicator stalk from the Mk1 to a FG Mk2 G6E, as they are not the same. The Mk1 has a separate switch for the driving lights (fog lights)
06/04/26 12:16 PM06/04/26 12:16 PM #2 strange requirement... but I'm sure with enough customisation of the wiring, it'd be do-able...
15/04/26 07:48 AM15/04/26 07:48 AM #3 On 05/04/2026 at 3:09 PM, TEZG6E said: I have a FG Mk1 G6E that is a write off. Can I fit the indicator stalk from the Mk1 to a FG Mk2 G6E, as they are not the same. The Mk1 has a separate switch for the driving lights (fog lights) What are you wanting to achieve? Only guessing at the following: Have you checked the wiring plugs that the stalks use? It might be that the plugs are the same, with a wire or 2 connected (or deleted) from different points on the connector.
