Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 17/10/23 06:17 AM Share Posted 17/10/23 06:17 AM All good mate, hopefully this gets it sorted and it's smooth sailing from here on out. Link to comment Share on other sites More sharing options...
Nick_is_not_sus Member 44 Member For: 6m 25d Gender: Male Location: New Zealand Posted 20/10/23 10:37 PM Author Share Posted 20/10/23 10:37 PM Hey a bit of an update...arrived at work at 7.30am manged to have a free hoist at lunchtime ( checked pan it was stone cold ) and threw it on the hoist with the car running you were 100% right, it took another 5-600mls of trans fluid .. gearbox is alot smoother still hangs in third after big hill but its improving... I have a Xtool PS80 at work and did a full car diagnostics no codes what so ever apart from p0420 which will be second o2 sensor from cat removal (not sure if I can delete that secondary sensor without messing with the tune?)..... I was actually really tempted to reset the learning on the TCM ... but while I was there I calibrated my speedo since I'm running 245 35 20s ....came to the conclusion that I'm going to drive the car around and put a few hundred more kms and drop the fluid again, I just think it was so contaminated (black).. I may be wrong but I dont think the trans has ever had a service it had the original green gasket I wouldn't think it would be reused right? .... I'm keeping updates going just so if anyone in the future has something similar Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,133 Member For: 9y 2m 29d Gender: Male Location: South Australia Posted 20/10/23 11:51 PM Share Posted 20/10/23 11:51 PM You can turn off the second O2 sensor in the tune but if it's just a code and not a MIL I would leave it. If you can see the adapts on the clutches with your scan tool, there's 5 of them, you'll have an idea of the condition of the box. I'll post a pic of the stock 3=>4 shift pressure in mbar, the adapts will add or subtract from that. While the adapts generally only add or subtract a few hundred mbar at most, you'll see this is actually a significant amount of pressure, especially at lower loads. If it's already adding pressure, which it will be as it's a bit old and worn, a reset will make the box slip into the next gear and flare between changes. It may even flare like a mofo and bang into the next gear like a clutch kick if you gave it the boot and shift it in manual mode, mine has done that after a reset. You can do a reset if you want to see for yourself, just be prepared to drive gently for a while until it's back to normal. I think a few weeks of normal driving will have it sorted. Leave the shifter in the normal auto driving position the whole time so it can do it's learning thing. Just a thought, if the box is adding pressure everywhere then the downshifts might also have more pressure and might want to hold the gear...dunno I ain't a trans expert Link to comment Share on other sites More sharing options...
Nick_is_not_sus Member 44 Member For: 6m 25d Gender: Male Location: New Zealand Posted 29/10/23 10:54 PM Author Share Posted 29/10/23 10:54 PM (edited) Bit of an update, still doing it not as bad I'm going to change the fluid agin soon. I think this time for piece of mind ill drop the mecatronics unit out and replace the seals and hopefully I should be able to inspect the internals a little more... another thought thought I had was how temperamental are the transmissions when it comes to rolling circumference? The factory option for my car is 245/40/18 I am running 245/35/20 stretched onto a 20x10 all round which ends up being a 4% difference in rolling circumference Edited 29/10/23 10:55 PM by Nick_is_not_sus Link to comment Share on other sites More sharing options...
