ngauge New Member 4 Member For: 4y 4m 1d Posted 11/03/21 04:58 AM Share Posted 11/03/21 04:58 AM Hopefully this is the right place to post this as I am in need of some advice, as this is the first time I've thought about doing any aftermarket work on my car. Ill try to keep it short. I bought my 08 XR6 Turbo Falcon second hand roughly a year ago and it's been great up until now (sitting at 136k as of writing), I've been doing research on what basic or preventative mods I should look at doing (trans cooler, battery replacement/turbo side intake, oil line etc). However a week ago I noticed a noise with the stock exhaust and after taking it to an exhaust shop I was advised ill need a new rear muffler. Obviously, being the cultured gentleman that I am im thinking about taking the opportunity and installing something with a little bit more...excitement than just replacing the stock rear muffler (xforce for example). I was also hoping that I could knock over a couple of jobs at once and get the new exhaust installed while doing the trans cooler and the battery replacement. Here's where the problem comes: after talking to a few performance mechanics here in Melbourne I was advised by one that if I install a new exhaust, and/or do a battery replacement that ill also need to get the car tuned. Does that seem right? This mechanic was trying to sell me on a stage 1.5 or stage 2 kit (including a tune which he says I need) plus the exhaust which is a significant expense. It seems a bit excessive/unnecessary to me to have to get the car tuned after simply installing a new exhaust and/or doing a battery replacement? Should I even be thinking about just getting the basic stuff done, or is going with a stage 1.5 etc kit the only real option I should be considering? Perhaps the better question is: besides getting the exhaust done professionally, is the battery replacement and trans cooler installs so basic that taking it to a mechanic is overkill and I should be doing it myself? Any help or advice anyone can share would be greatly appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,593 Member For: 17y 3m 2d Gender: Male Location: Melbourne Posted 11/03/21 05:05 AM Share Posted 11/03/21 05:05 AM If you replace the catalytic convertor or injectors/fuel-pressure-regulator then you definitely need a tune... anything else that changes the airflow (in via the intake or out via the exhaust) doesn't generally need a tune to suit nor does a lift-fuel-pump in the fuel tank. But if you do a turbo-side intake replacement only (from a performance modifications point of view, you definitely don't need a tune, but it's a good idea to do certain mods at the same time (which almost always is including a tune) to get more than just a sound increase out of your mods You can do any mods yourself if you think you have the skills and tools/products to get it done to your satisfaction. Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703219 Share on other sites More sharing options...
ngauge New Member 4 Member For: 4y 4m 1d Posted 11/03/21 08:14 AM Author Share Posted 11/03/21 08:14 AM Thanks so much for the reply. I have been toying with the idea of doing the turbo oil line and the battery replacement myself (mostly thanks to the info I've read on this forum) but now that I have to get the exhaust done it seemed logical to do it all at the same time. But then the mechanics started talking about stage 1.5/2 kits which seem to include a lot of things I dont need (at least not yet). The price of those kits and the tune (which seems unnecessary at this point) is why I hesitated and came here seeking more info and advice. I believe the exhaust I would get installed (assuming I go for something other than the bare minimum of replacing the broken muffler) would be a cat-back system, so I assume that means im not touching the converter? (happy to be corrected on that though). Again, thanks so much for the adivce. Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703221 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,040 Member For: 10y 2m 19d Gender: Male Location: Canberra ACT Posted 11/03/21 09:30 AM Share Posted 11/03/21 09:30 AM That's correct - if you are installing a cat-back system you will not be touching your catalytic convertor and don't need a tune. There is info on here about reputable tuners if you decide to go down that path one day. But sounds like the place you visited is a bit like the guttering bloke who came to my place to fix a single gutter leak. Told me it would probably be easiest to replace all of the gutters and downpipes for $8.5k. Technically would have fixed the problem... Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703222 Share on other sites More sharing options...
ngauge New Member 4 Member For: 4y 4m 1d Posted 11/03/21 09:59 AM Author Share Posted 11/03/21 09:59 AM Yah that's what I thought, he seemed like a good bloke but my Spidey Sense started to tingle when he started talking about these kits and a tune as being necessary and the only way to go. Seemed a bit much for what I was talking about doing. Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703223 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 3m 13d Gender: Male Location: Perth, WA Posted 11/03/21 11:22 AM Share Posted 11/03/21 11:22 AM (edited) For what its worth, getting a mid muffler delete from the stock exhaust makes a huge difference to the sound and tone of the car. One of my favourite cheap mods I've done to my car. Cost me $100! If you're not chasing big power gains, I reckon you'd be better off looking for a 2nd hand stock exhaust to fix your leaky one, and get the middle muffler removed at an exhaust shop. Yes the x-force systems sound good - but they're expensive. Middle muffler delete sounds good and is a fraction of the price. https://www.youtube.com/watch?v=FFVju9b6WI4 (@k31th is there a way of making embedded YT thumbnails smaller in a thread? 😜) Edited 11/03/21 11:31 AM by biddie_fiddler Didn't like the huuuuge embedded video view Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703225 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,593 Member For: 17y 3m 2d Gender: Male Location: Melbourne Posted 11/03/21 11:28 AM Share Posted 11/03/21 11:28 AM How small would you want it? Lol. The width of the post box is fine... You can just make it a URL instead of an embed if you want to save space haha Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703226 Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 6y 3m 13d Gender: Male Location: Perth, WA Posted 11/03/21 11:29 AM Share Posted 11/03/21 11:29 AM I feel like I'm wasting precious reply space by embedding the whole video 🤣 I'ma remove the embedded view I think Continuing on from your post, OP, if you want decent induction noise, the battery relo and 4" intake stems are awesome! I've helped install a plazzy, mackielec, and antz battery relo & intake kits. They are all basically the same. Quality wise the plazzy one was mint but is on the pricey side. I'd recommend the mackielec or antz systems for awesome bang for buck products. Additionally, installing these is a f%#k tonne simpler if you install them along with an I/C piping kit. The stock I/C piping, on the hot side specifically, can get in the way. Not impossible to install without I/C piping though, just real tight! Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703227 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,593 Member For: 17y 3m 2d Gender: Male Location: Melbourne Posted 11/03/21 11:37 AM Share Posted 11/03/21 11:37 AM Haha suit yourself bud Link to comment https://www.fordxr6turbo.com/forum/topic/96183-basic-mods-and-tuning-question/#findComment-1703229 Share on other sites More sharing options...
