bitcrusher Member 38 Member For: 4y 11m 25d Gender: Male Location: Melbourne Posted 27/06/20 08:57 AM Share Posted 27/06/20 08:57 AM When I removed exhaust manifold to change engine mount I noticed 1 bolt had been changed for a longer as due to a threaded hole though I tightened it to much and its I <3 Bananased, also the same with another bolt. So I have 2 threaded holes which are minced and was thinking about fixing and replacing with studs? Whats the longest bolt I can put into the head. Some suggestions and information would be appreciated thanks Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,536 Member For: 17y 1m 28d Gender: Male Location: Melbourne Posted 27/06/20 09:03 AM Share Posted 27/06/20 09:03 AM that's pretty standard as there's a couple of longer ones for the engine removal bracket and the heat shield... and if you move these you have to change those bolts if you wish to not cause damage to the threads. helicoil the threads and upgrade to studs or go with replacemetn bolts. Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/#findComment-1696254 Share on other sites More sharing options...
bitcrusher Member 38 Member For: 4y 11m 25d Gender: Male Location: Melbourne Posted 27/06/20 09:05 AM Author Share Posted 27/06/20 09:05 AM When I purchased car didn't come with heat shield currently in the search for one. how long of studs could I use? Wondering if I could use larger studs to solve the problem Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/#findComment-1696255 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,536 Member For: 17y 1m 28d Gender: Male Location: Melbourne Posted 27/06/20 09:31 AM Share Posted 27/06/20 09:31 AM just buy the stud kit that goes with this car, if you think you want them specifically. I doubt you'd be able to do it the way you're suggesting without creating other potential problems. Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/#findComment-1696257 Share on other sites More sharing options...
bitcrusher Member 38 Member For: 4y 11m 25d Gender: Male Location: Melbourne Posted 27/06/20 09:36 AM Author Share Posted 27/06/20 09:36 AM need to fix threaded bolt holes before just putting in studs Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/#findComment-1696259 Share on other sites More sharing options...
f6mark Member 2,909 Member For: 14y 3m 24d Gender: Male Posted 03/06/25 10:30 AM Share Posted 03/06/25 10:30 AM On 27/06/2020 at 7:03 PM, k31th said: that's pretty standard as there's a couple of longer ones for the engine removal bracket and the heat shield... and if you move these you have to change those bolts if you wish to not cause damage to the threads. helicoil the threads and upgrade to studs or go with replacemetn bolts. Thanku keth. Your life saver mate. Link to comment https://www.fordxr6turbo.com/forum/topic/95805-threaded-exhaust-manifold/#findComment-1726347 Share on other sites More sharing options...
