St33nXR Member 26 Member For: 4y 10m 19d Posted 12/06/20 12:41 AM Share Posted 12/06/20 12:41 AM Ill be pulling my turbo barra out of my ba that had afire inside and putting it into a na ba is there anything major I have to look out for I know ill have to do a parameter reset cheers Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/ Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 8d Gender: Male Location: Canberra ACT Posted 12/06/20 01:04 AM Share Posted 12/06/20 01:04 AM Take the module on the ICC, the PCM, ignition barrel and locks if it is all undamaged - that way you wont need any coding.You'll want the LSD too (and I think the tailshaft, trans and CVs are different on the turbo too - but someone else might confirm that 100%) - so basically transplant the turbo driveline into the new car. Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/#findComment-1695769 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,452 Member For: 17y 21d Gender: Male Location: Melbourne Posted 12/06/20 01:34 AM Share Posted 12/06/20 01:34 AM yep, transplant the entire driveline and electrical components as Andrew said. Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/#findComment-1695772 Share on other sites More sharing options...
St33nXR Member 26 Member For: 4y 10m 19d Posted 12/06/20 03:38 AM Author Share Posted 12/06/20 03:38 AM Easy the barrel is gone fire was at the insode fuse box will salvage what I can but everything else is good will remove it all and transplant thanks guys Is it possible to not transplant locks and stuff I know I need the ecu and stuff but are the codes hard to sort out? Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/#findComment-1695782 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 10y 8d Gender: Male Location: Canberra ACT Posted 12/06/20 04:55 AM Share Posted 12/06/20 04:55 AM Nah don't worry about locks if you aren't keeping the ignition barrel.You will need a Ford dealer or someone with the software to marry up the PCM, the module on the back of the ICC and your ignition barrel and keys. There are a few guys around who do it - some may even provide a postage and return service so you don't need to tow the car. Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/#findComment-1695784 Share on other sites More sharing options...
St33nXR Member 26 Member For: 4y 10m 19d Posted 12/06/20 05:03 AM Author Share Posted 12/06/20 05:03 AM Yeah to easy will defiantly look into it jist gotta find the time to pull 2 lots of everything out and then put it in haha cheers for the tips everyone will post back here if I need some more info bunch of legends 1 Link to comment https://www.fordxr6turbo.com/forum/topic/95764-swapping-my-xr6-turbo-engine-into-a-na-xr6-both-bas/#findComment-1695785 Share on other sites More sharing options...
