k31th less WHY; more WOT Site Developer 28,311 Member For: 16y 18d Gender: Male Location: Melbourne Posted 26/05/20 06:35 AM Share Posted 26/05/20 06:35 AM For a basic set of mods: injectors, fuel pump, actuator, tune... that's all you really need... the intercooler/intake etc allows more room for repeatability of power delivery. Valve springs are optional, as discussed above. The key thing to remember is, you have an engine with weaker rods if the build date of your car is before June 2006, so pushing up towards 300rwkw would risk the motor in that circumstance. Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 23d Posted 26/05/20 06:39 AM Share Posted 26/05/20 06:39 AM Actuator not needed for those power levels. Stock turbo will run out of puff before actuator can't handle the handle.Talk to your tuner. I recommend Maxx Performance. Zane knows what's what. Link to comment Share on other sites More sharing options...
Antonioxr6t New Member 9 Member For: 3y 11m 2d Posted 26/05/20 06:41 AM Author Share Posted 26/05/20 06:41 AM For a basic set of mods: injectors, fuel pump, actuator, tune... that's all you really need... the intercooler/intake etc allows more room for repeatability of power delivery. Valve springs are optional, as discussed above. The key thing to remember is, you have an engine with weaker rods if the build date of your car is before June 2006, so pushing up towards 300rwkw would risk the motor in that circumstance.I have the bf 07 mk2 stronger rods Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,311 Member For: 16y 18d Gender: Male Location: Melbourne Posted 26/05/20 06:44 AM Share Posted 26/05/20 06:44 AM that's good, then. you can feel a bit safer in your search for more power 7 minutes ago, cat007 said: Actuator not needed for those power levels. Stock turbo will run out of puff before actuator can't handle the handle. That's completely wrong. The stock actuator is about 7-8psi on a BF. If you want it to hold boost properly into the 'teens of PSI, the stock one won't do a good enough job and you will probably need to port the exhaust housing to control boost properly at the 14+psi levels. The turbocharger itself will make 20+psi in the mid-range without trouble, so the turbo isn't running out of flow at 'teens of PSI levels (about 18-19psi is the most a GT3582R can hold in a 4L motor at higher revs, but that's still higher than what this guy is aiming for at this stage). Link to comment Share on other sites More sharing options...
cat007 Member 234 Member For: 5y 7m 23d Posted 26/05/20 07:05 AM Share Posted 26/05/20 07:05 AM Alright. Then do this.Fuel pump and cradle.Regulator.Injectors.Intercooler.Turbo side intake.High flow cat.Charge pipes.Valve springs.Spark plugs - 0.7mmFlex fuel if you can afford it.Tune with above and ~300rwkw on 98 or 350rwkw on E85 - minimum. Maybe another 50 on top of each. Link to comment Share on other sites More sharing options...
