CCCC miso xr6 Donating Members 317 Member For: 15y 4m 18d Posted 01/01/19 06:28 AM Share Posted 01/01/19 06:28 AM (edited) Hi everyone, does anyone know were I could buy a alternator that has at least 130amp for a ba falcon xr6 turbo sedan, I do know fg have 130amp but there a 3pin while ba are 2 pin. Has anyone modded a fg alternator to suit ba? Reason I ask is the car is suffering bit of voltage issues were my car drops dangerous amount of voltage while running, I run 3 pumps and a few other accessories and I know these sapp some amps. Edited 01/01/19 06:31 AM by CCCC Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,310 Member For: 16y 17d Gender: Male Location: Melbourne Posted 01/01/19 07:03 AM Share Posted 01/01/19 07:03 AM hmm, sorry, can't help you directly, but I'd be very interested to hear how you get it done, when/if it gets done. my guess would be talk to a auto-electrician about it. Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 11m 2d Gender: Male Location: Central Queensland Posted 01/01/19 07:43 AM Share Posted 01/01/19 07:43 AM In tried using a 2 wire, 160 amp alternator from a Ford Mercury. The fitment was fine, but I had issues with overcharging at high rpm. I believe that it got to around 17 volts at 6,500 rpm. I thought that it may have had a faulty regulator, so I replaced it and tried again. The overcharge remained and I was fortunate that it only blew the headlight bulbs. After this, I decided to refit the factory unit while I sorted the rest of the car. Unfortunately, I haven't got back to it.. 1 Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 4m 18d Posted 01/01/19 07:58 PM Author Share Posted 01/01/19 07:58 PM I will let you guys know if some how I can get the fg alternator to work, thanks @HI PSI for your reply as I now know not to push amps that high now. Link to comment Share on other sites More sharing options...
HI PSI Member 1,572 Member For: 17y 11m 2d Gender: Male Location: Central Queensland Posted 03/01/19 09:18 AM Share Posted 03/01/19 09:18 AM I don't think that it is an amperage issue. More likely an over speeding of the alternator. Link to comment Share on other sites More sharing options...
Hunter99 New Member 10 Member For: 2y 8m 19d Posted 08/08/21 01:19 AM Share Posted 08/08/21 01:19 AM Does anyone know if you can fit a ba alternator (2 pin plug) into a bf xr6 falcon with the 3 pin plug will it cause any issues if I just make a adaptor or something... Link to comment Share on other sites More sharing options...
