02/09/18 02:46 AM02/09/18 02:46 AM #1 Hi guys, I have a 2004 BA XR6 turbo that's had high fuel consumption and rough idle for months now. I have changed the oxygen sensor, Throttle position sensor and most of the rubber seals on the air intake manifold/ throttle body and turbo. I've also given the throttle body a good clean and reset the ECU/TPS. The car doesn't feel like its gonna stall any more but the idle is still a bit rough. The needle doesn't sit still and fluctuates up and down over about 100/200rpm. The fuel consumption hasn't changed at all. I know the manifold isnt leaking. There has been no noticeable loss of power. Here are the symtoms: - fuel consumption has jumped from 13lt/100km to 17.8lt/100km - idle was pretty rough. Sometimes stalling at the lights - while accelerating under load when the car still fully hasn't heated up it feels like the fuel cut off comes on, the car loses power and wont accelerate further until I remove my foot from the accelerator. Any help/suggestions would be much appreciated.
02/09/18 02:59 AM02/09/18 02:59 AM #2 sounds like either coils or a collapsed cat. just guessing, though, as that sort of thing could be difficult to diagnose.
02/09/18 03:09 AM02/09/18 03:09 AM #3 Author The coils were the next thing I was going to check. Who do you think would be the best a diagnosing the issue? Pro tuners with a dyno?
02/09/18 04:08 AM02/09/18 04:08 AM #4 Yep, a tuner who's an expert at these cars is your best bet for a quick diagnosis. If you're in Sydney, then you can check out this thread to choose from the quality places around, if necessary. -> https://www.fordxr6turbo.com/forum/topic/82602-recommended-tuner-workshop-new-south-wales/
