January 3, 20179 yr #1 When I.m driving yesterday, the dsc fault light suddenly come on the dash, I stopped the car checking all my lights, all works fine. What could be the problem? Abs light never come on, dsc light only come on and off,.When I restarted the car, it went off. Then back on. I had a flat batteries before, could that be the cause? This time of the year all dealers are closed, I.m off to a long trip next week, any advice I can fix this? Thanks
January 3, 20179 yr #2 have you changed anything or had any work done recently? if it's the battery, you'd probably notice other errors, not just DSC. often it's the brake switch (by a cursory search). could also be a dirty ABS sensor. could also be the brake globes if you've put LED's in.
January 5, 20179 yr #3 Author Now the abs light come on too, if I clean and replug the abs sensor will that help? I check my brake light seem all working fine
