sm13f6 Member 34 Member For: 10y 3m 27d Posted 25/10/16 05:42 AM Share Posted 25/10/16 05:42 AM hey guys got a 2007 bf f6 , been tuned and so on blah blah recently it has been running sh*t on idle ( 5 cylinders ) then come good after 5-10 seconds just brought up cyl misfire , check it with a noid light and it drops power when plugged into the injector but when you just have the noid light in it keeps flashing with no drop out iv changed ecu today , and its still doing the same thing , even swapped the no 6 injector and coilpack round and still does the same thing on cylinder no 6 on idle will drop power or earth when plugged in to the injector anyone have any ideas or had same problem before I burn the thing to the ground haha thanks Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/ Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 11d Gender: Male Location: Adelaide Posted 25/10/16 09:18 AM Share Posted 25/10/16 09:18 AM The wiring harness or even the injector plug must be suspect then so strip it back and check it out and then Give the engine block a new clean earth from the battery and rince and repeat your testing procedure Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618256 Share on other sites More sharing options...
sm13f6 Member 34 Member For: 10y 3m 27d Posted 25/10/16 09:56 AM Author Share Posted 25/10/16 09:56 AM Yeah I ended up running a new wire from ecu to injector and same thing but it did bring up this fault so im thinking maybe a coil pack wiring problem as I changed coilpacks and does the same and it causes it to cut signal to injector also as a safety maybe ? P0356 - ignition coil 6 primary secondary circuit Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618258 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 11d Gender: Male Location: Adelaide Posted 25/10/16 10:08 AM Share Posted 25/10/16 10:08 AM What injectors and what plug arrangement ? Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618260 Share on other sites More sharing options...
sm13f6 Member 34 Member For: 10y 3m 27d Posted 25/10/16 10:52 AM Author Share Posted 25/10/16 10:52 AM 1000cc with the plug adaptors but have swapped injectors around and used different plugs and it stays on no6 Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618262 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 1m 11d Gender: Male Location: Adelaide Posted 25/10/16 11:00 AM Share Posted 25/10/16 11:00 AM Have you swopped the adapters around aswell as I've seen the adaptors bugger up from time to time if you've changed everything around and run a new cables from the ecu direct to the injectors and swopped the ecu out and swopped the coils around id look at the coil harness and look at running some clean new grounds from the battery to chassis/block Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618263 Share on other sites More sharing options...
sm13f6 Member 34 Member For: 10y 3m 27d Posted 25/10/16 11:06 AM Author Share Posted 25/10/16 11:06 AM Yeah swapped adaptors round and eveb used new ones and same sh*t Haha Yeah ill suss the coil wiring tommorow and put some new earths on too So over it haha only does it on idle aswell which is annoying Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1618265 Share on other sites More sharing options...
Mufasta Member 4 Member For: 11y 5m 17d Posted 05/02/17 12:17 PM Share Posted 05/02/17 12:17 PM thread dig - hey mate, did you ever get to the bottom of this? im having the same issue now Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1630897 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 5m 12d Gender: Not Telling Posted 05/02/17 12:33 PM Share Posted 05/02/17 12:33 PM Whether or not it has been solved or is this issue in this instance, I'll chuck in 2c worth of info. Injector drivers in the pcm can fail. Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1630898 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 7m 11d Gender: Male Location: WA, Perth Posted 07/02/17 02:21 AM Share Posted 07/02/17 02:21 AM (edited) looking at @sm13f6 user profile, the last login was 03/02/17 04:08 AM. so you missed him by 4 days. Hopefully by tagging him, he will login soon and see your post @Mufasta. Hopefully he resolved the issue and will post the solution in here. Edited 07/02/17 02:22 AM by masda74 grammer 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92592-no6-injector-pulse-drops-out-on-idle/#findComment-1631000 Share on other sites More sharing options...
